Hello!
I am swapping in an LHU in place of my blown out LNF and since the motor is so clean, I wanted to use the LHU intake and exhaust. So my question, is the Map sensor on the LHU the same 2bar as the LNF? I can't swap them (tried, different size hole in manifold), do I have to swap the intake or will it run fine?
I bought the motor used with 36K miles, and it was complete with intake, exhaust, turbo, throttle body, and belt with all the accessories. If you don't think I should just use the whole engine, please let me know.
Thank you!
