I?m doing a LS1 swap with drive by wire. I need to buy a PCM and choose an operating system.
Is there a best or preferred year Corvette PCM/OS I should use?
2001 or newer.
Physically that are all pretty much the same P01. The OS just needs to be a vette version
94 BB Rx-7 02 LS1
There is no difference between the PCM's themselves. The OS is also the same. It's just the tune that may be a tad different from year to year. P01 is the PCM model like E38 for the newer cars.
Another name for it the is 0411 PCM.
94 BB Rx-7 02 LS1
I believe all Gen3 motors used the same physical PCM minus the 1998. Just the OS was different.
94 BB Rx-7 02 LS1
Looking at some stock tunes from the repository, it looks like they switched to a "P59" PCM in 2004. Any info on significant differences between the P01 and P59?
Different pinout. Blue/Green(P59) vs Blue/Red(P01) connectors. P01 had 512kB memory and P59 had 1MB.
Just use the P01/0411 PCM and LS1/LS6 vette type harness. Don't over think it.
94 BB Rx-7 02 LS1
