Results 1 to 5 of 5
Thread: tips for dialing in light throttle MAF?
    Jan 2016
    332
    I'm having a bit of a difficult time dialing in my MAF in the light throttle region (for reference...see my signature below for my set-up). At idle...it sits around 1600 hz. At cruise...it sits around 3000 hz. Its the 2000-3000 hz range that is giving me a tough time. When on deceleration, the wideband is showing very fat in this area. When trying a very light acceleration sweep, it showing very lean in this area (5%-20% lean).
    Any tips on what I might be doing here? I'm thinking maybe I should ignore the deceleration fatness and simply tune using a very light acceleration sweep? Or is this typical of MAF tuning for this light throttle area and I should ignore it?
    Do I need to remove my VE air PID to log MAF correctly? I know that the MAF air PID needs to be gone to do VE properly...wondering if its the same way vice versa.
    Any tips would be much appreciated here....
    2010 Camaro LS3
    Kenne Bell 2.8 Supercharger
    BTR stage 3 PDS Torque Cam
    Frankenstein M311 heads
    9:1 forged rotating assembly
    Speed Engineering Headers
    ID1000 Injectors
    Twin return fuel fuel pump
    PLX Wideband
    HP Tuners
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Do the low rampup off idle in neutral and just feed pedal.
    Can leave ve for maf tuning.
    Ed M
    [email protected]
    Jan 2016
    332
    Quote Originally Posted by mowton View Post
    Ed M
    Got it. Thanks!
    2010 Camaro LS3
    ID1000 Injectors
    PLX Wideband
    HP Tuners
    Mar 2010
    Texas Hill Country
    3,299
    dont tune the maf with any decel data. filter your data to exclude decel by using a percentage of pedal. make sure DFCO is disabled also
    Mar 2007
    Florida
    3,772
    Another good way to filter is using Fuel Trim Cell parameter as a part of your filter string. With your 2010 Decel is either 7 (Evap open) or 15 (Evap closed). Good data resides at 0-5 and 8-13 with idle (6 and 14) rounding out your choices.
    Ed M
    [email protected]
