It's driving me crazy, a little bit of details, Vehicle is a 2013 Jeep Wrangler Unlimited, Auto, 4.56's, 35" tires, no modifications to the engine, no supercharger or anything, 91 octane since day one despite what the damn manual says , it's a got a much of extra weight courtesy of steel skids, bumpers etc, about 400lbs more than stock, but the gears get the job done without issues.
KR only seems to manifest itself when the outside temps are hot, 6-8* KR according to the PID, nothing on the WOT side, only during part throttle, between 0.52 and 0.60g aircharge, and 1700-3100 rpm.
Initially i thought it was just as simple as removing 2* from the part throttle timing table, from there i did remove up to 3* from the table, only to see the same amount of KR.
Then i thought maybe the KR was related to high IAT's, so i started playing with the IAT table, same results, tried removing as much as 8* from that table, only to see the same amount of KR in the logs.
So as a test, i loaded the factory timing, and pumped 5 gallons of 100 octane with 9 gallons of 91, so the cocktail was around 94 octane, freaking KR was still there more or less in the same areas.
I did modify the KS sensitivity after that test, increasing the knock sensors threshold volts by about 15%, to my surprise, KR is till there, better, but still there, and i don't think i want to continue numbing them down, i thought i'll halve the long term KR table as a way to desensitize the KS logic a little further, but i wanted to ask for more opinions.
Looking at some other KR PID's 3 days ago, i noticed we have a short term KR, and long term KR pid, and i started observing this values, most of my KR seems to come from the long term KR pid, while some sporadic one is short term, so it makes me wonder about this specific PID ?
Is this long term KR a combination of other knock retard adders like IAT or ECT adders?, and i'm just chasing my tail for nothing ?
I'm attaching mt factory and modify tune, as well as my last log form today with my modify tune, hoping somebody can give me some more pointers on how to address the issue, perhaps something i'm not seeing in my tune.
There are 2 logs, both were taken with the same tune, the only difference was 94octane in the tank, vs 91 octane for the other.
Thanks a lot
