Page 4 of 12 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 239
Thread: done dug a hole i think
  1. #61
    Jun 2013
    207
    and its got a supercharger tab that I'm wanting to play with but I aint sure what it does
  2. #62
    Tuning Addict
    6,899
    Supercharger tab won't do you any good...
    Map wasn't maxing in the log I viewed - make sure when your scanning that your logging the correct map parameter - I believe some of the parameters don't display correctly - you'll also want to log more things like airmass, knock, burst knock, torque limiters and so on - new scanner will show you much more info if logged...
    Under torque management - left hand side in V2.25 or newer - trans input max / trans output max - you can raise these and test
    Also noticed last cell in MAF low isn't the same as first cell in MAF Hi - make these two the same
    To make sure your map is input correctly - key on engine off - kpa should equal your barometric reading for your altitude - believe your in Florida? Should be something around 100ish kpa?
    ~Greg Huggins~
  3. #63
    Jun 2013
    207
    think I got torque handled and injectors now what u think is goin on with that map do I need 3 bar or just see what happens with injector change and torque fixed
  4. #64
    Jun 2013
    207
    Alright I'll git that handled too
  5. #65
    Jun 2013
    207
    I will be adding channels fer sure, my Autel reads more at the moment
  6. #66
    Jun 2013
    207
    im on the sae map pressure channel i think its the right one it reads 103 which is purty close
  7. #67
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by jessiewalls View Post
    alright i got a 12615136 map sensor what should the linear and offset be ? and is there any other changes that need to be made?
    I believe that one is linear of 200 kpa and the offset should be 10.33.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  8. #68
    Jun 2013
    207
    more i mess with that torgue spark the better it gets
    , i preciate all u fellers help
  9. #69
    Tuning Addict
    6,899
    Once you get those injectors in and request manifold volume from HP's website, I would recommend doing some other things to better get it in line and keep it from going lean during throttle snaps and so on... I can list these out later tonight possibly... Make sure to request manifold volume from HP support, so they can get it added...
    ~Greg Huggins~
  10. #70
    Jun 2013
    207
    how do i go about the hp tuner request??? i got the data for the injectors that i have so im gonna try that first , also added a bunch of chanels
  11. #71
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Send the request to [email protected] with a copy of your tune.
    Tell them Greg said hurry it up
    Just kidding on the last part
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  12. #72
    Jul 2013
    Clear Lake tx
    423
    you need to get an info file thing too
    http://www.hptuners.com/forum/showth...acting-support
    2010 CTS-V A6, Airaid CAI, 2.4 pulley, ported ls7 throttle body, ID850s, ARH 1-7/8" headers and X pipe, TR7IX plugs, MSD wires, Elite catch can, ZL1 lid and Track Attack HX
  13. #73
    Jun 2013
    207
    alright im on that next
  14. #74
    Jun 2013
    207
    got that sent to hp support, what is that gonna do for me?
  15. #75
    Jun 2013
    207
  16. #76
    Jun 2013
    207
    they said tell greg to do it his dam self
  17. #77
    Jun 2013
    207
    jkk
  18. #78
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    lol
  19. #79
    Jun 2013
    207
    any idea whats going on with my over 100 percent load?
  20. #80
    Tuning Addict
    6,899
    Great now I'm in more trouble
    Over 100% is normal, just didn't think at 50% throttle you should have been seeing 180 or whatever it was Injector data helps calculate all of that I believe because it will adversely skew the MAF and fueling tables in general...
    Carson, what's your engine load go to since it would be all but identical - roughly same boost anyway on a 6l? Yours is a 6l right?
    ~Greg Huggins~
