Results 1 to 10 of 10
Thread: Could someone look over my tune??
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Well after a few days of testing and logging, I feel I have come up with a half decent tune... most KR has disappeared, but I think the reason I'm still getting some is due to my IAT being on average at 135*F!
    Anyway here it is, if any I6 owners are in, try it out and let me know what you think.. its a pretty safe tune...
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    May 2006
    Tucson, AZ
    62
    hey bro... i just looked over your tune and it looks pretty good. one question i have is why is your PE delay set to almost 5,000 RPM??? I have my PE enable at 2400 RPMS and at 70% throttle. that way i can enter PE as soon as i hit my gas as i drive around at like 2000-2200 RPMS
    other thing i would change if i were you is under your Torque Management tab i would go to the Spark retard reduction and 0 those tables out becuase they pull timing to reduce the torque your motor puts out
    2005 Chevy Colorado
    4/4 drop
    1.25" thick front and 1" thick rear sway bars
    Nitrous Express wet kit
    billet servo
    JL12W7 in custom ported box w/ Phoenix Gold 1200.1
    Mar 2006
    Kuwait
    1,564
    great, thanks for the tip, i wasn't too sure what the spark retard did so i just left it as it was...If i zeroed them alllll out with this give noo TM whatsoever??
    and about the PE, would i get more "power" if i enabled it at around 2400rpm?? I'm still very new to all this tuning..
    Bader Norris
    MEP Tuned
    Instagram
    May 2006
    Tucson, AZ
    62
    you'll get PE to enable at that RPM as opposed to 4800.... it's more like getting that power earlier and longer that have in the upper RPMS lower.. i am fairly new to tuning as well... and yes if you zer out that spark retard table you won;t have any more TM except what ever your other tables are at...
    2005 Chevy Colorado
    4/4 drop
    billet servo
    May 2006
    17
    How many PE parameters have to be met in order to enter PE mode? Just changing the enable RPM will not necessarily cause PE to come on sooner.
    May 2006
    Langhorne, Pa
    102
    Well, on the I5, I know that theres about 3 or 4, but the rest of them are set in such a way, that really the RPM controlls it. I set mine to 850 rpms so I can have that power before I even hit a 60' marker on the strip.
    2007 Mustang GT
    266rwhp 276rwftlb's. 13.6@104 stock.
    Adding a bunch of goodies and shooting for mid 12's.
    May 2006
    17
    I assume you have separate tunes for the track and "normal" driving. Otherwise your gas bill is going to be enormous.
    28,314
    Quote Originally Posted by Blandmiller
    whys that? if your talking about PE use the pe enable tps vs rpm table
    Mar 2006
    Oxford, Ohio
    43
    Quote Originally Posted by foff667
    That table really isn't relevant if your TPS is 100 WOT because WOT is over all the stock values in that table correct? Is there any reason it wouldnt be in PE at WOT?
    Is there any way to actually log if the computer is in PE mode or not using the scanner?
    28,314
    Quote Originally Posted by blackeco
    huh? thats what its used for...to determine tps enable % to enter pe.
    yeah if one of the enablers isnt enabled like a time enabler or rpm enabler
    yeah, status bit.
