I just bought hptuners and an LC2 wideband. Same thing happens with me. 3.0.8 VCM scanner. I add the channel, click record, and it disappears from the channel list Subscribing for updates.
3.0.8 is very old. You need to update to the latest.
We got this guy Not Sure, ...
my mtx-l works fine far as I can tell with 3.08
I have had zero issues with it for years. Same sensor for a LONG time.
This is for SERIAL inputs. Not 0-5 V inputs
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
www.hptuners.com
Can either go to customer page or just hit "Free demo, try before you buy" on the homepage
Or direct link:
http://files.hptuners.com/VCM%20Suite/VCM%20Suite.msi
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Just download and Install? I already have Editor and Scanner installed...will it only update what is needed? Thanks for the quick reply!
Yes, just download and install and it will take care of it. Probably best to save the layout you're using beforehand but I usually don't and have never had any issues.
btw the reason many innovate users are having issues, is because their innovate product is so old, it doesn't use the ISP 2 (innovate serial protocol 2), it uses the one just before that. I do plan to add support for those.
FYI, those devices are likely 12+ years old.
Hi Keith, I just got Beta Access so I could try the latest versions with my LM-1 and LC1 - Both don't work probably for the reason mentioned above! I know these units are OLD but the LM-1 has been a very trusty device for me so I still like to use it.
Are you looking for anymore information on the connectivity issues with these devices? It sounds like your already on top of it, but please if there is anything you need from us "users" that can help please let us know.
I had some time to do a bit of testing on this today. Here's what I found...
VCM Scanner version #3.1.266
Innovate LM-1: Doesn't work
PID's are going blank when starting Datalog
Innovate LM-2: Doesn't work
Innovate LC-2: Doesn't work
When the sensor shows fully lean I see AFR 20.9 as O2 comes down readings go into the hundreds/thousands. Seems like 500 "MAY" be around stoich but hard to confirm.
dan_t, contact support.
I'm going to want to see a debug.dat for the LC-2.
OK will do - Im unsure of how or where to create the debug.dat I'll ask support also.
I have to get a log for support but just wanted to say that my mtx-l does the exact same as Dan-ts lc-2
Debug file sent - Ticket # 34158
Installed my new AEM 30-0300 wideband, connected the serial to usb adapter to the laptop, set up the channel and whe wideband reads 0.98 and the channel reads 9.8. any differences in the wideband reading and the decimal is always 1 digit to the right. i emailed support on this. thank you
Got BETA ver 3.1.300 and are my results from a serial input of an LC-2. Here are my findings in screen shot form:
This is programming the LC-2 and gauge for AFR Stoich and channels and graphs to match.
This is programming the LC-2 and gauge for Lamba and channels and graphs to match.
Last edited by mowton; 04-30-2016 at 05:17 PM. Reason: corrected beta version number
Matt,
Generate an email to [email protected], state LC-2 Serial not working and include the file Debug.dat found in HP Tuners>Settings
Ed M
[email protected]
Will do thanks!
Matt
