Quick question.
I'm building a 350 small block with a stealth ram and hoping to put boost to it.
I am using the 0411 with express van tune. I'm wondering if I should use the 60 lb injectors or the 80 lb injectors. I have greg's injector data so I think I have decent data or either one.
I'll use a 3bar OS and am hoping to get 600 or so rwhp (unless that's an unrealistic goal).
Some basic info on the setup.
Chevy 350 engine with trw dish pistons.
8-9:1 compression depending on what heads I can find.
Holley Stealth-Ram intake with edelbrock rails, stock lt1 throttle body and AEM adjustable regulator
Stock crank and rods.
Hoping it will survive with a 6000-6500 redline.
Thinking of the On3 76/65 turbo or the 78/75 turbo if it would be that much better for the setup.
Pretty set on the Siemens injector just because I can get them for a steal through work.
Thanks all for input!
