I like to setup the Editor and the Scanner each at half screen so I can look at the log results and the program at the same time (i.e timing/airmass logged and the timing table to see if any reductions/additions are being enacted). The way it is now, you can kinda manage the chart and graph screen but the channel table doesn't have room.
Per the split screen approach, I would really like to see a link between the scanner data and its applicable editor table to allow you to follow as you scroll through the log. The piece of resistance (:-)) would be to add, what I have seen called a "Runway mode" where the row and column at the two scanned axis points are shaded and intersect at the data value...and track as you scroll through the log....maybe after all the critical stuff is addressed.
Ed M
