Have you logged Master Fuel Correction yet....
That PID will tell you in short form which table is either currently limiting fuel or is getting ready to limit fuel.
Ill give it a try in a few mins here. Working with the truck atm actually.
Getting boost P.F. when i log the master fuel correction.
That's a boost fuel limiter kicking in.
The PF is "Protection Factor"
Can i simply disable that in the limiter table? Wanting to keep my wastegate shut anyway.
So what do i need to do to stop it from limiting my fuel rate? Adjusting my limiters down to 160mm3 from the max i had them set at has my load logging correctly now so thats a plus It will now measure the percent by how close the commanded rate is now. But im still dropping fuel rate. Got a high speed error on the last run when logging master fuel correction, but the truck broke the tires loose pretty bad went through a couple gears... Any suggestions?
Look at the RPM limit table. You are probably limiting fuel rate based on RPM.
RPM limit table is set to 159.986
Look into your rpm limiter tables...several in there in Stock form will begin to pull fuel around 2800
two logs attached. desired RP is correct.... and its shooting long enough... i just need to get the rail pressure up...
https://www.dropbox.com/s/78grl1g32m...aved1.hpl?dl=0
https://www.dropbox.com/s/o62js3p6fw...saved.hpl?dl=0
Let me know your thoughts.
You are commanding 5500uS....
With 5500uS, 3100rpm and 18* of main timing...your on the verge of melting something.
You need to seriously stop what your doing and slow down with your changes.
I didn't stay at a holiday Inn Express last night but I agree 1000% with what Les has just said.
Please take a step back from the keyboard.
Like i mentioned the duration doenst matter because it doesnt run anywhere near the volume its supposed to since i cant get the commanded fuel pressure to run correctly. If it was i wouldnt be at that long of a duration.
Like i mentioned no smoke, no high EGT, no rattle... nothing... so by upping the PW its just running the same or less fuel pressure for longer but not getting the qty of fuel i need at all.
Once i get help on the FP issue, ill halve the PW which should get me right around where i want to be.
Lower your pulse to a reasonable amount and your FPA will rise
it will because the truck isnt asking for as long of a duration. are you saying that its a diminishing return to go over that?
If you look at saved1 it never gets over 17k psi... is there something also to make the FPR more aggressive?
also stock is 2000us... are you saying that the max amount we should increase the 140 value is 1000us?
also you guys dont sound like jerks i was thinking the same thing when i was tuning this.. if it ever did hit commanded fuel pressure it would put so much fuel in i agree it would melt the pistons..
but i havent figured out yet how to get the rail pressure more agressive.
editing again - Is it possible that the CP3 is the culprit since its not modified at all? i dont remember it being an issue with smarty at all before.....
update - new logs. Hitting 0x34 air density limits, but i thought i had the master protection piece off. guessing it is seperate and thats my problem?
https://www.dropbox.com/s/xlh6gongjze477f/log4.hpl?dl=0
https://www.dropbox.com/s/2m1bemypo3ben2h/log5.hpl?dl=0
William Collins
04.5 Billet 48re-S366-DDP 90's-HP Tuners-Dual cp3.
SDX 2011- 611/1091 Judgment Day 2011-641/1340 2.6 class Winner
Yeah its an auto. Im also having an issue when u go WOT at 65mph it goes to down shift and sets at 32-3300rpm and bucks. When i log main fuel correction its saying high speed govnr i also get the boost P.F.... Never noticed this new issue of the down shift until last night when i kicked it down on the hwy to do a log.
