Thread: not getting commanded afr
    Potential Tuner fbamj's Avatar
    Dec 2010
    Dumas Tx
    4
    I can not figure out why I cannot get the fuel where I want it under wot? I'm using an LM1 tied to hp tuners. LS1 with 36 lb. injectors mild cam, headers, I should have it very rich with the tune in it. See if anyone can find what I'm missing. Thanks Mike
    1999 Camaro 5.7 cnc heads, .608/.608 cam, 3700 conv., 4.10 gear
    1968 C-10 chevy short wide 5.7 78mm turbo 3600 conv 3.70 gear
    1978 chevy luv 6.0 cnc headed .568/.590 cam 3200 conv 3.90 gear all smiles
    13,599
    What is the wideband saying compared to your PE setting?
    Set up your PE to what you want to see at WOT, so like 12.5. Then you must tune the VE and MAF tables.
    Your VE is choppy is some spots and the MAF table is not completely smooth, couple dips.
    After that you would only add the the VE or MAF to increase or reduce fuel. You don't screw with the PE table to get more fuel, thats not the right way to do it.
    Dec 2010
    Dumas Tx
    4
    haven't smoothed either of them yet after setting them today. This is the way I have always corrected wot afr. I'm using maf not doing sd tune. That was only time i used ve to correct fuel.
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    It is a good idea to log AFR commanded and AFR error so you can see on your logs. It will make your tuning process easier.
    It is a good practice to use AFR error as well for fueling if you are using a wideband.
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
