Page 12 of 14 FirstFirst ... 2891011121314 LastLast
Results 221 to 240 of 265
Thread: HP Tuners Virtual VE Support added to 2.25.1063+ Beta
  1. #221
    Downloaded the latest beta today and when working on a c7 when copying the data over to the GMVE it transferred fine with copy and paste. However, when I hit calculate coifficients it distorts the numbers badly that where just pasted in
    You need to adjust your zones in the areas that are distorted and re-smooth and recalculate the coefficients.
  2. #222
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by wetcoast View Post
    Yep.
    It will always change the numbers some.. It's basically "best fitting" equations to fit the data you've put in. It won't fit perfectly though.
    The key is minimizing the distortions.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  3. #223
    Aug 2009
    Calibrating
    3,379
    I don't understand how a zone adjustment will help? I want the GMVE table to calculate what I pasted in (should be simple, has worked fine since this newest beta)
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  4. #224
    Aug 2009
    Calibrating
    3,379
    My GMVE values go from 2200-2500 I. The zones I'm working at to -1800 to -500
    That's a HUGE distortion
    14 Gen 5 Viper
  5. #225
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Got any screenshots or tune/values you're plugging in so we can try to help?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  6. #226
    Tuning Addict
    6,896
    Ben how are you data logging gm ve for the c7's? I know they're all map/baro instead of just map axis. Only reason I ask is because new scanner doesn't seem to work with the map/baro and not sure how to set up 2.24 to do it.
    ~Greg Huggins~
  7. #227
    Mar 2010
    Texas Hill Country
    3,299
    Ben Charles, this is exactly the issue I was having a while back. It corrected itself after a new version came out, it sounds like it broke again. It's like the auto-smoothing it does when you apply changes is messed up.
  8. #228
    Mar 2010
    Texas Hill Country
    3,299
    If you have a 2014 you can still use 2.24 and it has Pressure Ratio pid available. Log Baro, MAP, and Pressure Ratio.
  9. #229
    Aug 2009
    Calibrating
    3,379
    No screen shot unfortunately, Higgs is right the "code" must be broken on yesterday's beta (updates daily) so I just stopped SD tuning and went back to Mass air.
    I'm using the 2.24 scanner, don't really care for the 2.25 scanner.
    I setup pressure ratio as [SENS.30]/[PID.51]
    I think that's the equation for map divided by Baro
    Also figured out a trick way to dial in the Driver demand tables
    I was seeing throttle percents not matching and now they are right on top of each other
    14 Gen 5 Viper
  10. #230
    Mar 2010
    Texas Hill Country
    3,299
    There is a Pressure Ratio pid, you dont have to calculate it.
  11. #231
    Tuning Addict
    6,896
    Yes, what little I've used the 2.25 scanner hasn't been very pleasant. I was glad to see the ford pids added and working correctly. Other than that, not really a fan.
    Don't guess there's any chance of sharing your driver demand logging setup? All though I imagine you could do the same thing that you have to do for Fords and then add a touch and be spot on?
    I just hope the vve isn't making the "city blocks" like it was a few weeks ago. Pulled my hair out for half a day trying to figure out what I did wrong in my base tune that was causing a false 2800 rpm rev limiter... That particular car got the stock vve left alone unfortunately...
    ~Greg Huggins~
  12. #232
    I've found that if the distortion falls on a zone boundary, if you move the boundary between the two (or more) offending zones that the distortion is notably less. You didn't see this with BlueCat because it automatically adjusted the zones to best fit the VVE table. One of the features I've requested be migrated to 2.25
  13. #233
    Tuner seevi's Avatar
    Jan 2009
    southern California
    80
    Has anyone written a procedure paper on using V V E editor in 225?
  14. #234
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Change cells
    Hit calculate
    Procedure complete
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  15. #235
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Change cells
    Hit calculate
    Procedure complete
    wait slower........:-)
    Actual don't forget to select Manifold open...
    Ed M
    [email protected]
  16. #236
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    AH yes, sorry. My bad.
    Though in all seriousness.. is there a way to change where the different zones are? I haven't messed with that but figured there had to be
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  17. #237
    Engine > Airflow > Dynamic > Zone RPM Boundaries
    Engine > Airflow > Dynamic > Zone MAP Boundaries
    2015 Cadillac Escalade ESV, 6.2L L86, 6L80e - AFM disabled
  18. #238
    Jan 2009
    southern California
    80
    Quote Originally Posted by mowton View Post
    Ed M
    Manifold switch open OR Manifold open (DoD)
  19. #239
    Aug 2009
    Calibrating
    3,379
    I make open and close the same values.. I don't even touch the DOD VE tables due to usually just disabling DOD
  20. #240
    Mar 2007
    Florida
    3,772
    Quote Originally Posted by seevi View Post
    Manifold Open..... unless doing DoD then Manifold Open (DoD) (separate set of coefficients)
    Ed M
    [email protected]
