I'm needing help with a start up tune on my 24x conversion in my v8 s10. I'm using the 99-03 truck pcm I've already moved the coil and injectors pins to correct the firing order difference. the engine is a 5.7HO crate motor with about 350hp with a edelbrock proflo-xt intake with 33lb ls2 injectors and stock 5.3 throttle body. i don't know much about tuning but i have hptuners and can navigate it ok but just have no clue what I'm looking at on setting stuff up. I've read some on how to set up the pcm. I just need a close start up tune i plan on getting it dyno tuned to make sure its all correct. thanks for any info...
