Page 2 of 9 FirstFirst 123456 ... LastLast
Results 21 to 40 of 163
Thread: VCM Scanner 2.25 Ford Tips
    Jun 2008
    Tyler/Longview, TX area
    746
    Is a negative value in STFT indicating that it's rich and a positive number indication it's lean?
    Oct 2007
    Crawfordville, FL
    2,447
    Quote Originally Posted by txcharlie View Post
    Correct
    Eric Brooks
    HP Tuners, LLC
    Jun 2008
    746
    Thank you Sir!
    Oct 2007
    Crawfordville, FL
    2,447
    I am told the scanner now supports DMR logging and Rapid Packet on the older Oak PCMs we support.
    We have to put it through testing and find / fix any bugs that may be there.
    Big news, especially for the Australian guys!
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by Eric@HPTuners View Post
    Awesome. That is great news. I am certainly keen to volunteer to test this (HACH3CA)
  6. #26
    Woooohooo!
    Quote Originally Posted by DarrylC View Post
    Same! Excited to try it out. FPAF0A3
  7. #27
    Oct 2007
    Crawfordville, FL
    2,447
    I'll email you.
    Eric Brooks
    HP Tuners, LLC
  8. #28
    Apr 2015
    westminster,sc
    where can i download 2.25 from
  9. #29
    Jun 2008
    746
    I did a log today and saw negative KR reading. Am I looking at this backwards? I thought a positive number was adding spark and negative was pulling spark.
    Can someone confirm that the KR is working correctly? Should I not trust the reading?
  10. #30
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by bigburrell View Post
    You must email support.
    We got this guy Not Sure, ...
  11. #31
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    157
    The way it worked on older Ford systems with the other guy's software is you have to think about it as Knock RETARD. So a positive number is "subtracting timing," or retarding it, and a negative number is adding timing or advancing timing. I believe that's how it's set up here but I've been waiting patiently for Eric to answer my question about it.
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
  12. #32
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Blown383 View Post
    Plot in chart view against Timing Advance and look for the corresponding dips or peaks in timing. That may help determine what event is taking place.
    Jaime
  13. #33
    Jun 2008
    746
    I did plot it against TA and thought I had it figured out. My log showed up to 8* of KR and was freaking me out since I didn't know if it was advancing or retarding. Then I plotted it against TA and it looked like some of the time is was advancing and some of the time it was retarding. All KR was positive on the log.
    I backed it up with a livelink log and it showed that the KR was adding(up to 8*) and pulling spark(up to 2*). So, my conclusion is the KR is NOT working correctly in 2.25.
    My last log with 2.25 had some negative KR(-1*) readings which has me confused. I turned all KR spark advance off in my tune. That's why I think KR is not working correctly.
  14. #34
    Jun 2008
    746
    Just did a drive log with livelink and the same tune that I logged with HPT scanner that recorded -1* of KR. Livelink showed 1* of KR(pulling timing), so from this info, I think HPT scanner is opposite Livelink. It appears -X* is retarding spark with HPT scanner and +X* is advancing spark.
    I really like the scanner and I'm learning all I can about it, but if KR is not working correctly, I need to know.
    Can someone from HPT please confirm or deny this?
  15. #35
    Apr 2015
    43
    Does the copperhead OS FSFD1AA.H32 have all the PIDs added? I'm not seeing any fuel pump, pressure, and injectors PIDs showing any data. Also, is there a way to export the log to CSV that I could analyze using MegaLogViewerHD? Thank you.
  16. #36
    Apr 2005
    Sugar Land, TX
    1,198
    Will injector pulse width be added soon? Sure would like to check my injector duty cycle. (for Ford 2013 GT500)
  17. #37
    Oct 2007
    Crawfordville, FL
    2,447
    It may read opposite. There is a -1 multiplier for that PID. I can set it to 1 if it makes more sense to have it read the other way
  18. #38
    Jun 2008
    746
    I'm good with it either way, but since it's called knock retard, in my mind a positive would mean it's retarding and a negative would mean it's advancing. I just want to know the way it's recording.
  19. #39
    Aug 2009
    Naples, FL
    339
    Leave it the way it is if a negative number is truly retarding timing
  20. #40
    Nov 2007
    232
    FPDLA5A2...no maf period no mapped points.
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
