This is a tune file I built for a Solstice. Stock K04 turbo, IC, Catless DP, stock airbox (possible drop in filter I am not 100% on that). 93 octane Pump gas. 3 logs ago the car threw a cam sensor code, misfires, on 3 cylinders and strangely a P0101 in there as well. On that log the car dropped rail pressure in spite of being no where near the stock HPFPs limit (0.89 PE lambda, 24.5psi max boost no big spike and stock turbo on 93 so yeah) I warned him that the cam sensor code was bad news and he insisted that somehow my tune caused all those codes including the cam sensor code. I told him there was zero chance anything in the tune caused the cam sensor code. Well 4 days later the motor blows on him while doing a pull and now of course he is blaming me 100% for his motor blowing. I of course stand behind my work and I told him that he could show his tune to any competent LNF tuner and they would agree that there is nothing wrong with or dangerous about his tune file. In fact it is pretty conservative overall because I knew he autocrossed the car so I left timing very low so constant wide open throttle would never cause knock. Well, I am putting my money where my mouth is. Feel free to look at this tune and give me your opinions.
Thanks,
Terminator
