I am trying to wrap my head around tuning the 2 VE tables on on 2011 Jeep wrangler 3.8. The axis on the VE table is RPM vs Ratio. What is this ratio? is it equivilance ratio? I am used to the LSX platform and am lost here.
I am logging manifold pressure (kpa) RPM, wideband AFR ratio.
I have put a 1320 eaton blower on it and trying to get the VE correct prior to returning to spark tuning.
Ratio is Pressure Ratio, and is a function of Manifold Absolute Pressure divided by Atmospheric Absolute Pressure.
So, at sea level where atmospheric pressure is 14.7:1, if you are running 14.7 psi of boost on the gauge (meaning 29.4 psi Absolute), your Pressure Ratio would be 2.0.
For me, where I am at 4500 ft elevation with an Atmospheric Absolute Pressure of 12.5 psi, if I were running 14.7 psi on the gauge (14.7 psi over my atmospheric pressure), my absolute pressure would be 14.7 psiG + 12.5 psiA = 27.2 psi Absolute in the manifold.
