Results 1 to 8 of 8
Thread: WB scanner reads different then HPT at WOT
    Dec 2014
    20
    I am running my WB through my EGR to read that data in HPT. That is all setup and working fine. At idle my WB reads 14.5-14.9 and HPT will read the same, i got it to read the same by altering the equation. However when i go WOT my WB will read about 10.5 where as HPT will read 11.5. Is there something that i am missing, haven't had much luck searching for the answer. Its the Innovate Motorsports 3844 MTX-L gague.
    13,608
    What you are seeing in HPT is just the commanded AFR, so it's very possible that you are still rich.
    Try working the MAF table to take away very small amounts of fuel and see if the wideband follows. Take away 2-5% at a time and see if the wideband creeps up to like 10.7-10.9.
    13,608
    I should note, only do this above 7,000 hz, as thats when you are likely already in PE and the only time it see's that much airflow.
    Dec 2014
    20
    I setup the custom wb Histogram i thought that gave me the normal AFR, the VE- Commanded AFR table shows 10.9 at WOT. Im still learning, but i will try to take away a bit from the MAF table and see if the wideband changes.
    Dec 2013
    Appleton, Wi
    12
    Can you post your config file you use when scanning? I can checkout your custom histogram and sensor/pid equations you setup.
    2009.5 SBM Pontiac G8 GT / Vararam CAI / Pat G Tune / HP Tuners / x-pipe mid muffler delete
    Dec 2014
    20
    Here is my config.
    wb7.cfg
    Dec 2013
    Appleton, Wi
    12
    what equation did you alter the one for voltage drop? histogram 8 parameter 4?
    Dec 2014
    20
    The afr PID equation is the one i altered.
