Results 1 to 20 of 21
Thread: Twin 61mm 5.3. 3 bar OS cannot get the car started
    Sep 2014
    12
    setup is 5.3 twin 61mm turbos and 226/229 114 cam, 4l80e, 60lb sieman dekas. im fairly new to tuning but i have read the threads for a few weeks now but for the life of me i cant get the car started in the 3 bar os. the car starts and idles and drives, on a stock tune, but when i switch to 3 bar Nothing. i pulled a base tune from the repository, i've set the MAF 101, 102 103 to no mil still nothing
    3BAR BASE.hpt
    Nov 2009
    All Around
    3,149
    map sensor, check with OS upgraded to 3 bar via scanner what your map sensor is ready at key on engine off... are you getting any codes or emergency power?
    Sep 2014
    12
    Quote Originally Posted by SultanHassanMasTuning View Post
    i'll check that this evening and report back, last i checked i was getting a p0106 code but ill check again this evening
    Feb 2006
    South Carolina
    1,525
    You need to set the MAF codes to fail on first error and set your MAF fail freq to 0 Hz to properly activate SD with HP Tuners. You want your MAF to fail instantly when keyed on and cranked the first time.
    ...and everything Sultan said about the MAP. That P0106 will need to be addressed.
    Jaime
    Sep 2014
    12
    Quote Originally Posted by ElecTech View Post
    Actually tried that a few times , maf codes Set to fail on first error and fail freq set to 0 still the same problem, i tried a few different settings as i had seen others on this forum set theres to no mil. But i will set it to first error and zero on maf fail this evening when i check the map
    5BA8
    3,525
    Is the VE even close to right? Did you copy/paste your 1 bar VE to the 3 bar?
    Definitely set the codes to fail on first try.
    email=[email protected]
    Tuner POWERZONE's Avatar
    Jul 2014
    HOUSTON,TX
    191
    With the 3bar tune, are you doing a write to entire or write to calibrate?
    POWERZONE- AUTOMOTIVE PERFORMANCE AND TUNING SOLUTIONS
    STREET TUNING/DYNO TUNING/TRACK TUNING/REMOTE TUNING/EMAIL TUNING
    [email protected]
    Sep 2014
    12
    Yes, also tried it with 3bar ve, samething. I will set codes on first try
    Sep 2014
    12
    Quote Originally Posted by POWERZONE View Post
    Write only for calibations
    Jul 2014
    HOUSTON,TX
    191
    Quote Originally Posted by lrj6 View Post
    I figured that.....
    You need to do a "WRITE TO ENTIRE" to apply the custom OS(3bar).
    After you change the OS then you can use the write to calibrate function.
    [email protected]
    Sep 2014
    12
    I figured that.....
    Thats what i did. I did write entire first to change to.the 3bar custom 2000 os from the stock tune,, then did write only for changes that i made.
    Jul 2014
    HOUSTON,TX
    191
    The car runs with that 226/229 camshaft and 60lb injectors on the stock tune perfectly?
    Post the tune you saved as your "stock tune".
    [email protected]
    Sep 2014
    12
    its starts, idles and drives and runs, i never said perfectly. But it starts when i switch it back to the stock tune. Plugs wires, are new
    Jul 2014
    HOUSTON,TX
    191
    Ok, post the stock tune, the one it starts with.
    [email protected]
    Sep 2014
    12
    Ok give me a few
    Sep 2014
    12
    Trying to upload a pic but im on a phone, it looks to be 105kpa for map with key on engine off???
    Sep 2014
    12
    Its the old school block style, i got it off of ebay theres no part number on it
    Sep 2014
    12
    Attachment 47283
    Attachment 47283
    map is supposed to be a 3 bar older block style. bought off ebay it has no part num on it
    Sep 2014
    12
    Attachment 47284
    codes p0748 p0405 p0102
    5BA8
    3,525
    All of your attachments are coming up as invalid.
