I am helping a guy tune his 01 Silverado. The truck has had a turbo for over 3yrs now. Originally it was ran up to 15psi on E85. Ran real good for a number of years that way. Now the truck runs 91 pump.
At the end of last year the truck started to become very sluggish and progressively got worse. During this winter the turbo was removed temporarily & the thing would hardly go. Fast forward to now and a fresher motor & a new 70mm turbo & it is still acting up.
It has been throwing 0101 & I have just started helping him work through this but I feel there is something weird going on.
In the logs the cruise shows way rich. The STFT is showing at times up to -30% fuel. The engine hesitates really bad when you first step on it, then cleans out but still runs poorly. The chugging starts at the first stab of the throttle at low vacuum so it is not a "In boost" issue. Replaced the MAF and PCM to no avail. If you run it in OL it runs worse so something is definitely not right.
I am not sure if it is an injector(s) issue or a wiring problem as of yet. It has LS7 injectors @70psi static, 255 inline, other than that it is a stock 5.3. Initially the truck had a WB on it but it was taken off for another project. I am going to loan him an extra one I have laying around so we can get a better idea of what it is actually doing fuel wise.
Perhaps someone can take a peak at the log & tune and see if I am missing something obvious that I am just overlooking.
The first log is before I started messing with it & the second log is where I addressed the 0101 & a few other drivability issues.
