Results 1 to 14 of 14
Thread: New to tuning need advice: Trying to tune open loop but AFR goes lean
    Sep 2007
    20
    I have been trying to tune in open loop so that I can dial my MAF sensor in. I have followed the help file in HP tuners for setting up open loop. When I flash my open loop tune to my car it runs very lean ~20:1 verified with NGK AFRM WB and doesn't seem to get much richer. I am commanding 14.6AFR. Does this mean that I am not actually in Open loop or do I have a table that is that far off that it is changing my commanded AFR that much?
    Any help would be appreciated, I am new to tuning so I want to find out if it is something that I am doing or if it is my tune.
    7.12.14 rx7 MAF ONLY.hptopen loop lean2.hplMaf tuning.cfg
    Feb 2009
    1,931
    I would check your wideband setup, does not appear to be correct.
    Sep 2007
    20
    What looks off about it? I have the wideband dispaly also hooked up in the car and it reads the same values.
    Feb 2009
    1,931
    you have narrow band o2 displayed and its displayed voltage does not corespond with your wideband displayed afr.
    Sep 2007
    20
    Thanks for the help! I never thought about relating the narrow band to the wide band. isn't a low mV on the narrow band a lean AFR?
    What confuses me more is when I flash my original tune back to the car the AFR drops back down to close to what is being commanded.
    Edit - I attached a scan with my original tune showing my AFR and the original tune that I started with.
    Feb 2009
    1,931
    Your narrow band is showing leaner then stoich, but at the 18:1 your log was showing I would expect the narrow band to be at 50 or less mv. I Suggest putting it back into closed loop and using stft to dial in maf.
    13,606
    Sep 2007
    20
    Thanks, I will follow that guide and see if my results change.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Turn off the AIR pump.
    Russ Kemp
    Feb 2009
    1,931
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Interesting, would not have thought of that. Is it not already off? Disable temp is 14 and log shows running at 185?
    Sep 2007
    20
    Do you mean the air pump for the emissions system? If so, I have the engine in a mazda rx7 and there is no emissions systems on the engine any longer.
    Sep 2011
    Portland, OR
    523
    Is this engine stock?
    If so, it should run pretty well on the stock tune.
    Did the ecm come with the engine?
    I don't see in your 2nd log that you are logging both O2 sensors. Or stft. Not really even clear if it has gone to closed loop. Irregardless of the tune.
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Sep 2007
    20
    The engine is not stock. It has an ls6 intake, ported throttle body, tsp 228r 112 , and long tubes.
    The ECM did come with the engine and I sent it to a well known tuner for a mail order tune when I installed the cam. The only thing I have added after the cam was the ls6 intake.
    I am going to be switching to an ls3 air intake and maf but I wanted to get familiar with tuning before I did the switch.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    If your tunes change the fueling that much and the only real difference is OL vs. CL. Chances are your base tables are off and the car is just compensating. I did not have time to look at the logs, but how much have you been increasing the MAF table to try to compensate for this?
    Sulski Performance Tuning
