Results 1 to 19 of 19
Thread: Tuning Help Big Turbo 5.3 FoxBody
    May 2014
    'Braska
    59
    Having troubles starting my fox body. 5.3 single.turbo. mods in SIG. Wondering if anyone can give me advice on changes I need to make. Used to be tuned for nitrous with timing retarded and a lot.larger lift camshaft. Ditched the Maf and went speed density with 3 bar map.
    1992 Ford Mustang - LR4 4.8 - BWS475 - LJMS Cam - E85
    1981 Chevy C10 SWB 4.8/60e - air ride *currently building*
    13,599
    You forgot to post the tune.
    May 2014
    'Braska
    59
    adam_turbo_fox_base.hpt
    Attempt at attaching tune.
    Sep 2011
    Portland, OR
    523
    First thing to do is to fail the MAF in the tune.
    Eng Diag/Airflow/Maf Freq Fail High to 0hz
    Then under DTC set P0101, 102, 103 to 0 Mil on first error
    In your VE Table, copy the original from 15-105 KPA and paste into the same area of your 3bar VE. The numbers you have there will flood the heck out of it.
    Your injector flow rate is certainly not for ID 2000;s? Those look like stock numbers.
    Fuel/General/Flow Rate/Flow rate vs KPA
    The rest of the injector data needs filled in as well. IDC website will have the data.
    Stoich needs to be set to 9.77 for E85
    You should also set the fueling to open loop. Fuel/Open and Closed loop/ECT vs IAT to 285 all of them
    Your timing tables are all wrong, and I don't see any retarded stuff for nitrous there?
    There is really a bunch of stuff wrong....are you sure this is the file you are trying to use to start this up?
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    May 2014
    'Braska
    59
    you're right, posted the wrong file. sorry
    Here is the latest i have:
    adam_turbo_fox_base_chad.hpt
    made a bunch of changes and still having no luck...
    May 2014
    'Braska
    59
    The problem I believe I may be having, I think it may be because the MAF will not throw a fail code. Stumped
    Sep 2011
    Portland, OR
    523
    Can you maybe get a start attempt log?
    Use the default imperial config.
    See what the rpm is doing.
    Might not have something connected?
    May 2014
    'Braska
    59
    adam_turbo_fox_base_chad_id2000.hpt
    BUMP: Entered the ID 2000 data and still not starting
    Feb 2009
    1,931
    boost referanced fpr?
    May 2014
    'Braska
    59
    Yes MagnaFuel Boost Referenced Fuel Pressure Regulator
    Jul 2011
    Houston
    45
    Have you checked fuel pressure?
    Feb 2009
    1,931
    Load this file(its yours modified) and load this config. Turn key forward, start log, then try starting car and report back.
    May 2014
    'Braska
    59
    Fuel pressure is good
    May 2014
    'Braska
    59
    Quote Originally Posted by mecanicman View Post
    thank you very much! will report back in a few hours! (currently at work)
    May 2014
    'Braska
    59
    https://www.youtube.com/watch?v=2nOqr2SX-9E
    THANK YOU TO EVERYONE THAT HELPED!!!!! Turns out i FU**ED UP when i painted my coil brackets...... ill be HONEST and admit that, yes indeed, i put my coil wires on reversed, on both banks of the engine...... But for whoever cares, there is the link to the startup video!
    Now who wants to help me tune this beast and make some POWER?!
    Sep 2011
    Portland, OR
    523
    Very cool! Really similar to my setup right down to the side exit exhaust.
    I sort of figured it was something simple......
    Mine lit first turn of the key. I was surprised
    Ron
    May 2014
    'Braska
    59
    startup scan 1.hplstartup scan 2.hplstartup slight rev.hpl
    Startup 1 - is the initial startup into idle
    Startup 2 - is idle
    Startup 3 - is idle with some slight rev
    Anyone care to take a peak and give me any input?
    Jun 2007
    Finland, Europe
    549
    Remove MAF PID from your scanner, as you don't need it.
    Otherwise the last log I checked looks normal; at least the PID's you were logging. Although narrowbands did not switch, but that's normal after startup and since you did not have Status Bit Display populated with closed loop parameter, I cannot be sure. Also there was a tiny bit of knock.
    Please remember: never trust just one opinion on Internet forums.
    Some handy info in here. Sub'd for future reference
