hey guys looking to purchase a good tune for a colbolt ss its a 2.0 lsj
just has intake and cat back,
pay via pay pal pm me please thanks
you cant really get a good flash in tune with the lsj. too many parameters to change to correct all of the factory reductions.
anyone have anything to start from? im just kind of in the dark here, its my borthers car.
Pm me
i will be firing up my secondary computer soon i can make a genuine lsj starter file. it will have adjusted pe and default to ve with minimal maf input. its just going to be like a day or two if you can wait. ill post it in your thread as an attachment for everyone.
Note: will also add it to the lsj bible as a main attachment for people wanting a good starter.
i have a tune for intake and header back exhaust, just messing with the pe tuning a little bit more and it will be done. Running it on my car. Right now I'm not using the ve table because of timing modifications.
If you don't correct the base you will not have a reliable end result. I changed the injector settings for both factory and stage 2 but it seems no one wants to go there these days
hey did you get file worked out, if so can u send it to me
wheres the info on changing the base injector data?? I've looked for it but good god I just cant find it
In for info
that sounds awesome,his car runs like a bag right now ,im waiting for my new interface cord,
what kind of gains do you think i can see out of this?
also thanks everyone who responded been lots of help =)
depends, I gained a lot of low end torque with mine, but it took a couple of weeks of messing with the timing tables to get them where I wanted them. As for wot, you do gain a little, and richening up the horribly lean stock a/f ratio makes it a lot safer. If you look at the stock values it take you into the 12s wtf gm
On OEM?
My OEM tune was nowhere near that. It was running 10's under WOT.
here you guys can use this if it helps you.
