The other day I was working on my truck (68 C-10 with an 05 5.3L in it)
The 05 ECM that I have is from a Yukon Denali with a 6.0L in it. I realized this, so I took a look at the tune from my '05 silverado (5.3L also). Using the compare function, I changed all of the settings in the Yukon ECM to match the silverado's (execpt for a few things such as VATS, and the DSCs since I don't have emmissions)
Anyways, two of the Parameters that I changed included "Pedal Desired Area". Tonight I was reviewing my tune and saw the warning at the bottom saying "Modify this table at OWN RISK. Incompatibility of this calibration with the vehicle TAC module calibration my render PCM permanently inoperable"
So a few days ago after I loaded up my new tune as well as hooked up a "pull up wire" to get my autometer tach to work I start up the truck. The truck starts up just like it should and I get a tach reading. I blip the throttle to see the tach move and the truck pretty much immediatly dies.
Now the truck won't start, the TPS shows 100% (the throttle body is closed btw) and I get a DTC error of
U0107 - Lost Communication With Throttle Actuator Control Module
P0606 - Control Module Internal Performance
Also I get a boot loader request timed out when I try to go back to my previous tune.
So I think this is what may have fried the ECM, not the tach wire mod. Anyone else have this problem?
