Results 1 to 13 of 13
Thread: Problem with mvpi
    Mar 2012
    26
    Problem with mvpi
    so for some reason all of the sudden tonight while tuning my car my cable started saying my pcm is not licensed,yet it has been for over a year on the same os and everything.is this a new found problem with 2.24 which I recently changed to?any ideas of what to do?cars now untuneable due to my cable saying a licensed pcm is not licensed.
    98 z28
    twin turbo ls6 4l80e
    28,303
    You need to license the vcm enhancement(custom operating system) that has been applied to the pcm(file) in question. Perfectly normal when attempting to use one of our custom operating systems.
    Mar 2012
    26
    Vcm enhancement has been licensed for over a year.i have been tuning the same pcm and os and enhancement for over a year so why would it all of the sudden would it be a license problem.also at one point when I was about to flash a file it said I couldn't and a firmware update was to be downloaded.i hit cancel and disconnected and reconnected and flashed it no problem.
    28,303
    Not for this one, you can clearly see that in the screenshot you supplied.
    Mar 2012
    26
    Then how have I been tuning 2bar sd on the same pcm for over a year? This pcm came from a different car and was licensed to a 2 bar os if this matters because mine got fried.
    Dec 2009
    1,084
    If it is a new PCM then it needs to be relicenced.
    Mar 2012
    26
    Pcm was re licensed a year ago and I have been tuning the same pcm for over a year.if a license is what I need so be it.still doesn't explain why its been tuneable for over a year and all the sudden not. Also any reason why my mpvi will not record?
    28,303
    You may have relicensed the stock operating system a year ago but since you are attempting to now utilize the 2 bar custom operating system you need to license that as well.
    Mar 2012
    26
    I have been utilizing the 2 bar os for the last year on the same pcm.i have multiple tune files showing that and there probly is even a file on here from the same pcm which is the one in the car.ill buy more credits on the 20th and add another license to reenable it and go from there.but at the same time im wondering if theres something wrong with my cable.since day one I have not been able to do standalone recording and last night the issue with the random firmware update.i figured the recording didn't work because of the io input issues I read about with beta.
    28,303
    Nothing wrong with your cable, maybe you are using the wrong file or something, hard to tell since the only thing you've posted is a screenshot, no infolog, no files, etc.
    Mar 2012
    26
    I may go grab the car on my lunch if I do ill post up my tune file
    28,303
    Or better yet email support a vcm suite infolog & the file.
    Mar 2012
    26
    email sent to support
    98 z28
