Results 1 to 20 of 32
Thread: Need help, more problem than I have knowledge $50 if you can solve it.
    1999 trans am
    390, turbo , 4L80e
    Here's the issue I accelerate and at right around 5500 rpm the pcm does a reset with the swing of the gauges and the trip meter reset, also my wideband looses power and resets. It does the same thing everytime. totally stumped.cutout2.hpl
    I attached a short datalog, frame 195 is where it does the reset, if you look at the afrs you can see how they drop down to 10 that's the wideband powering back up.
    I'm thinking it's somewhere in the electrical, I datlogged the voltage and it does it everytime.
    If someone knows what's causing this I will gladly paypal you $50. Worth every penny to get this resolve.
    thank You
    Also I recently installed 28" rear tires with 26" fronts so the abs, brake and tcs light are on.
    Jun 2007
    Finland, Europe
    550
    Please remove MAP (SAE) from your Scanner Table Display. It will now spoil your MAP readings.
    Jun 2007
    Finland, Europe
    550
    Simple question: do you have any error codes when it does this? And remove also BARO sensor, you don't need that information..
    Do you have a ported TB? I'm guessing your problems are related to Engine Diagnostics department. Unless there's something mechanical (including electrical stuff).
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    I bet you have a loose or disconnected ground.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2007
    Finland, Europe
    550
    I think Dsteck is the winner. As always.. :-)
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    ^^^^ often the case^^^
    I've also seen expanded retaining pins in fuse positions that show good when you touch them but drop when you lift off. Same with relay pins.
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    No error codes, no ported tb, checked grounds multiple times, pulled intake and checked grounds on the back of the head with multi meter. It does it every single time in the exact parameters.
    Aug 2008
    Chicago
    98
    My first guess would have been checking grounds. I would check power and ground going the pcm and condition of terminals etc. The 99 model year trans am and camaros had problems with the trip meter reseting which was caused by low ambient temps and low voltage. I know it doesnt exactly pertain to your problem but maybe low voltage is a possible reason for it. Also, how do you have your wideband powered up? If you need schematics i can get you what you need.
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Jun 2012
    225
    Could the traction control or ABS be causing your problem with the bigger tires?
    Quote Originally Posted by gagliano7 View Post
    I was thinking that, I pulled the abs/tcs fuses, disconnected the abs module and disconnected the wheel sensors. Didn't fix it.
    Quote Originally Posted by 01SLPSSM6 View Post
    checked grounds, I have the wideband getting power from the fuse box inside the car. I attached a picture of the cover, I tapped power from the IGN
    thanks for everyone's help. I just unplugged the wideband just to verify that it wasn't the issue and no change. The only thing I have done recently is install 2" taller drag radials, Could it be a TCS/ABS problem? I have the tcs/abs fuses pulled and disconnected the large connector from the abs module, also disconnected the wheel sensors.
    Apr 2009
    613
    Check the ignition switch on the steering column
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Aug 2008
    Chicago
    98
    So after looking at a schematic I noticed that the gauge fuse and the ign terminal are tied together in the fuse block. That pink wire from the gauge and ign terminal also sends power to the Instrument panel cluster. I would be leaning toward an ignition switch like flame mentioned
    Aug 2008
    Chicago
    98
    Being powered up on the same circuit would probably explain why the wideband and IPC are losing power. I would also connect your wideband straight off the battery, that's what ive always been told is the best way to have on hooked up.
    thanks, installed a new ignition switch today, haven't had a chance to test yet. I really appreciate everyone's help
    no the ignition switch didn't fix it.
    getting really bummed out that I can't get this figured out.
    Apr 2009
    613
    Trace the power feeds to the ignition switch there has to be a bad connection loss of voltage in there somewhere
