2001 3.8 series II camaro L36. stock motor, turbocharged, intercooled. 180 thermostat. ngk tr6 plugs, 91 octane
i'm running a 8# spring in my ebay wastegate. Through 1st and 2nd gear my autometer boost gauge shows 5psi. and in 3rd gear it creeps up to 10.
i'm not sure if the gauge is incorrect or if its the wastegate. so it could be 8psi and 13psi.
regardless, in 3rd gear i'm running single digit timing. and about .78 lambda. which is 11.5 afr i'm getting up to 6 counts of KR once i hit 3rd gear/higher boost.
any advice? is there anything in my scans i'm missing? i know i need to get my fuel trims adjusted for part throttle they used to be dead on. but its been sitting for a while. i plan on getting some race gas. and seeing if things change. i forgot to log maf hz in this scan so its missig the afr error histogram. but u can still see the lambda error in the table.
should i richen it up for higher boost?
use another step colder plugs?
