I finally got the car to be able to start and it will light off for half a second and immediately die. I double checked all the connections and wires and found nothing. My gauges appear to be working as well as everything else. I've got a 3 bar map and the 3 bar tune applied. The RPM registers on the scanner but not the gauge cluster.
I removed the fuel filters and cleaned them, there was a very small amount of trash in them. So I didn't think that would help when I saw them and I was right.
With KOEO the map reads 72.1kpa. I have 3 codes that I have no idea what the last two are.
P0452: Fuel Tank Pressure Sensor Circuit Low Voltage
P0748: Pressure Control Solenoid Circuit Electrical
P1637: Generator L-Terminal Circuit
