Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: eforce corvette tuning newbie question
    Dec 2008
    on the Dyno
    1,825
    I have done a few EForce kit'd cars and they leave alot to be desired for sure! One was a Hennessey car and I'm hoping they left that car with the can tune because it was a TURD when I got it.
    Located in Central Kentucky
    ShorTuning
    Aug 2011
    30
    Quote Originally Posted by 85mcss View Post
    Does anyone have a copy of the LS2 E-force tune in an M6 C6?
    Check in the tune repository, there may be one there
    2008 Corvette C6 A6
    E force 599HP kit, 3.25 pulley
    ZR1 Cam, ATI Balancer
    160 stat, Dewitts Radiator
    LG 1 7/8 Superpros, delete cats, xpipe
    Century Built 6l80e, Ext. Transmission Cooler
    3200 Yank
    2.73 rear
    Nov 2012
    10
    Quote Originally Posted by mrgillies View Post
    been there, done that..
    I didnt have a handheld tuner to start with so I was trying to find something to start the car with.
    I took my ECM to Ed Wright yesterday for him to tune so hopefully I'm where I need to be..
    Jun 2007
    Finland, Europe
    550
    Amazing stuff in these E-force tunes, though this is just the first one I've played with.
    Engine was knocking quite audible, though just momentarily but at least two times and ignition advance just keeps climbing. What an earth can be reasoning for these minimum spark table values:
    And why there's an Empire State Building in a High Octane timing map? Luckily just after redline, but anyway...
    Advanced Tuner yonson's Avatar
    Nov 2007
    MiSSiSSiPPi
    234
    Quote Originally Posted by Pekka_Perkeles View Post
    [img]http://img546.imageshack.us/img546/9408/heavyknock.jpg[mg]
    [img]http://img89.imageshack.us/img89/3434/empirekmx.jpg[mg]
    What vehicle is that from?
  6. #26
    Jun 2007
    Finland, Europe
    550
    Quote Originally Posted by yonson View Post
    2010 SS Camaro with L99 engine.
  7. #27
    Nov 2007
    MiSSiSSiPPi
    234
    I haven't ever seen that in any of the E-Force calibrations. Do you have a read of the ECU before programming with the Edelbrock programmer?
  8. #28
    Jun 2007
    Finland, Europe
    550
    No I don't, since I'm not the person who installed the Edelbrock kit.
    It's a good question, though, but I doubt handhelds are able to update just part of the ignition map. It think it's been flashed with SCT or something similar handheld.
  9. #29
    Tuner in Training SAM_69's Avatar
    Mar 2011
    Chicago.IL/Jeddah.ksa
    23
    Quote Originally Posted by mowton View Post
    Yes, and will you be surprised
    Yes he will
    EFI Tuning Specialist
    Chicago.IL
  10. #30
    Mar 2011
    23
    Quote Originally Posted by pekka_perkeles View Post
    and why there's an empire state building in a high octane timing map? Luckily just after redline, but anyway...
    lmao!
    Chicago.IL
  11. #31
    Nov 2007
    MiSSiSSiPPi
    234
    Correct, they use an SCT programmer, those programmers only write the changes that have been made to the file, everything else is left the way it was before programming, so if you don't start with a factory calibration in the ECU you have issues like you are seeing.
  12. #32
    Nov 2007
    MiSSiSSiPPi
    234
    The "Empire State building" in your HO Table is because the factory calibration in that area is 15 degrees, as is the Edelbrock calibration. Had they started with the factory calibration it would still be 15 degrees, but the car had been tuned while N/A and 25's had been put in those 4 cells, when the Edelbrock calibration was loaded on top of the non factory calibration those 4 cells weren't changed because they were supposed to be the same as the factory calibration.
  13. #33
    Jun 2007
    Finland, Europe
    550
    That my explain a lot.
    Does the SCT have a backup function? If so, I will definitely want to check what was in the car before flashing.
  14. #34
    Nov 2007
    MiSSiSSiPPi
    234
    Yeah, if you have the SCT programmer it would have backed up what was in the PCM. It should be under Program Vehicle, then return to stock.
