I had an AIS kit with a pressure switch tied off of the intake mani and used the WWF tank with a Devil's Own tank tap. Mounted the pump in the space between the front bumper and LF wheel well.
Started spraying at 10 psi.
'12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
About 1.5 gals or approx 18 mins of boost at 5 gph.
i think the passenger tank from an lsj would fit but idk if all the mount points are the same? seeing as the additional tank would be more of a saddle system you would have to connect the two with a transfer hose to keep the levels same or run dual pump ($$$)
