Page 7 of 8 FirstFirst ... 345678 LastLast
Results 121 to 140 of 152
Thread: mpvi pro standalone wideband logging
  1. #121
    28,311
    Standalone should work fine in 2.23.621, the only thing disabled is the analog inputs.
  2. #122
    South Carolina
    22
    Well great...I was wondering why I kept getting the error light when trying to data log without my pc. So is this resolved now? I'm gonna have to agree that it's pretty shitty that your selling a product with feature that doesn't work.
    98 Trans Am, M6, 3.90's, Lid, Z06 MAF, LS6 intake, EGR & AIR delete, ARH LT's & ORY, Magnaflow CB, & a little giggle gas.
    I got 98 problems, but Vtec ain't one.
  3. #123
    28,311
    Quote Originally Posted by 98prblms View Post
    Make sure to email support with an infolog so that we can email you once the software update is ready.
    Our hardware designer finished up the firmware and we just need to do some alpha testing on it this week to make sure its stable enough for public use.
    Thanks,
    Bill
  4. #124
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    Thanks,
    Bill
    and the analog's will work?
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
  5. #125
    28,311
    Quote Originally Posted by robbyredneck View Post
    No
    http://www.hptuners.com/forum/showpo...&postcount=110
  6. #126
    Jul 2008
    Louisville, KY
    417
    When will the analog inputs be ENABLED?
  7. #127
    28,311
    New Firmware is in the newest beta, I've emailed everything that has emailed support regarding this with the update. If you didn't receive an email and need access please email support.
    Thanks,
    Bill
  8. #128
    Jul 2008
    Louisville, KY
    417
    There are two things going on here, both are completely separate from one another.
    a. we recently found our chip supplier changed id's on the memory chip so we are creating a new firmware update to fix this issue so standalone datalogging works on the interfaces affected(which is very few in the grand scheme of things).
    b. analog inputs disabled in the beta software
    As stated the firmware is pretty much done and we just need to integrate it into the software.
    Either way a and b are completely separate issues handled by completely separate individuals within our company.
    Okay so when will "b." be enabled?
  9. #129
    28,311
    Quote Originally Posted by SargeZ06 View Post
    One thing at a time.
    Hopefully sooner than later.
  10. #130
    28,311
    Pre defined inputs enabled in the newest beta, for anyone that wants the update check your customer page, if it shows 2.23 you already have access, if your customer page only shows 2.22 email support with your MPVI Pro serial number and we'll post the update to your customer page.
  11. #131
    Mar 2011
    The Bush
    169
    What's the build number for the newest Beta Bill?
    tia
  12. #132
    28,311
    2.23.847ish
  13. #133
    Mar 2011
    The Bush
    169
    2.23.847ish
    Thanks, just grabbed 844 from my dealer, how exactly do I go about getting the new one from Support?
    <edit> Think I might have sorted it!
  14. #134
    Mar 2011
    The Bush
    169
    Got it thanks Bill!
  15. #135
    Tuner in Training mefreema's Avatar
    Jan 2012
    Michigan
    11
    "Pre defined inputs enabled in the newest beta,"
    So Does this mean that situation b. is now working too? I am using an AEM wideband with the analog input. I "think" it was pre defined, as in an available option within the software, so will I be able to do stand alone logging with the ability to capture my AEM wideband with it?
    2006 GTO M6 T76 Turbo Intercooled
  16. #136
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Thanks for the update Bill.
    Just to be clear... EIO *is* enabled in this beta in stand-alone logging and must be used with Pre-defined PIDs for external input logging; NOT user-defined, correct? I just want to make sure I understand exactly what you are saying.
    Thanks again; sounds like you guys are getting us going in the right direction!
    Steve Williams
    TunedbyFrost.com
  17. #137
    28,311
    Correct, with that said I think you might be able to log input voltage which you could make a custom pid from temporarily.
  18. #138
    Jan 2006
    Richmond VA
    1,950
    That's where I was going with that!
    Since that last post, I was wrapping up a car on the dyno. For grins, against my adjusted user-PID used for an AFX, I loaded the canned AFX PID. It was off a little less than two tenths (though close to that) around idle and the error actually decreased down around 11.0:1 AFR. It's been a long time since I have used that; I was pleasantly surprised to see it track as closely as it did.
    Thanks for taking the time to clear this up.
    Steve Williams
    TunedbyFrost.com
  19. #139
    28,311
    New beta up with the aux inputs enabled as well now.
  20. #140
    Potential Tuner SlowFiero's Avatar
    Jan 2009
    Alberta Canada
    5
    Can the new beta run custom pids on the stand-alone data logging, you said no, but does last post mean yes?
    Will GM 3-bar map be added to the EIO options list, currently only have 1 and 2 bar as options, it would be nice to be able to just select 3-bar instead of having to create a custom setup.
    1986 Fiero GT
    L36 3800, 6262 billet turbo, 206/206 cam, ID1000, 4T65E, 235/60R15 M/T DR.
    10.263 @ 134.44 MPH with 1.49 60' @ 3130lbs
