Results 1 to 16 of 16
Thread: FAST 85 and Bosch 80 injector data
    If anyone has the injector data for either of these injectors, I would appreciate it! The Bosch injectors flow 850cc at 3 bar, and the FAST injectors flow 825cc at 4 bar.
    Oct 2008
    297
    anyone have a tune with fast 85 injectors to view??
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    scale it manual with the unit conversion
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Quote Originally Posted by vette_c6 View Post
    Vette C6
    I like your signature, though in my case I would put "stop raping your MAF and IFR tables!" I've seen some jigsaw puzzles more than quite a few times in those 2 areas.
    Jun 2008
    Kuwait
    390
    hehhehhehe ,,, with raping it ,, you can run it ,, but when you fix it you will get always more power ,, less injector duty cycle
    i used to be PE raper :P! but not anymore ,,
    this is a pic a car i tuned ,, was raping the fuel ,, look at the injectors
    same car with hotter weather when Bob morreale came to me ,, he showed me the differents
    Abdullah Al-najdi
    00965 99369929
    Ok riddle me this riddle me that, I know the data doesn't exist, so I'm curious about how I did my IFR table. It has a return style fuel system (A&A), so I made the IFR one flat number. Should I have made it a linear table like stock? I am having some start up issues. Everything else on the car is great, just having a lean start up issue.
    Jun 2008
    Kuwait
    390
    If u are running on ur maf
    U can just rich it by the maf
    U dont need to mess up with everything
    And for setting all ur injector number as only 1 number
    For example
    55 55 55 55 ... 55
    Its not wrong
    But u always have to have ur resons if someone will look at ur tune
    Good luck
    Abdullah Al-najdi
    00965 99369929
    I appreciate your willingness to help, but that's not really the answer I was looking for.
    Dec 2009
    Slave Ship
    199
    Quote Originally Posted by FastEddy View Post
    If the regulator is vacuum referenced, make it all the same number.
    I called FIC this morning and John was happy to send me the excel spread sheet on these injectors. So problem solved.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,856
    Too bad it's ripped off data from ID. Lol. Hacks.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Ha, ironically they told me it was the other way around.... and I didn't even ask! lol
    Sounds like the whole "HP Tuners hacked LS1 Edit" claim carputing used to always make. That's why the first release of LS2 Edit was locking ECM's, because they didn't want it to happen again lol
    Mar 2008
    St. Louis, MO
    4,856
    Ask FIC about the cease and desist letter they were served back in December.
    Ask for pictures of their bench test setup or how the data's even gathered. ID will readily provide anything.
    This is just their break in rig. 30 minutes of varied operating conditions and pulse widths with actual gasoline, just to break them in before actual testing.
    And just because I like to stir the pot...
    Original ID1000 data sheet: http://www.injectordynamics.com/ID10...03-23-2011.xls
    Funny screen shots:
    Kinda odd how the FIC data sheet talks about a scaling article with no link, isn't it? Oddly familiar format... Just look at the revision history too. Paul Yaw is the guy who ultimately developed the data.
    I never said I had any reason to doubt you. Nor do I really care to get involved in all the dramatics.
    Mar 2008
    St. Louis, MO
    4,856
    Apparently you do, Chuck. Lol. Slander would imply it isn't true, btw.
