AFR ~15.3 on Fuel Cutoff resume at WOT
Hi,
I need some help as I don't understand why the AFR goes from ~10 before reaching Fuel cutoff (6400 rpm) to ~15.3 when resume fuel.
If I release the trottle for a bit then go WOT again the AFR will stay at ~10 until it hits the cutoff then resume fuel with AFR of ~15.3.
I try to look around in the config file but I couldn't point what making this happening.
I'm racing a Grand Prix GTP (L67 + XP cam + 42.5 injectors) on a circle dirt track and I stay on 1st gear (shifting 2nd gear isn't a good option).
Thanks for helping!
HP Tuners Owner
you are missing the RPM Limit AFR table, pleae download and install the beta software 2.23.596 or later to see the table.
Contact support with your cable serial # for access to the beta.
Chris...
I got the new beta 2.23.596 and I can see that table. I just max the thresh from 10 time to 65,535. this should take care of my AFR issue.
I will confirm tomorrow if it worked.
Sorry for the delay... This new beta took care of my problem. thanks again!
HP Tuners Owner
Glad its working, good luck with the racing
Thanks,
BTW I won the 6 cylinders final at the races.
