Results 1 to 15 of 15
Thread: Nos Tuning help
    Aug 2011
    19
    Nos Tuning help
    Im using a 200 wet shot of nos on 2011 grand sport c6 auto need to no if i need to change the low octane table for timimg as well as the high tables and is thier another table i need to adjust the timing besides the high/low octane tables
    Jun 2008
    Charleston, SC
    969
    how are you spraying it? plate or nozzle/ direct port?
    Aug 2011
    19
    plate
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    assuming that you have tuned your car
    lower your timing 6 degrees
    make sure when you run it with nitrous your AFR is below 12
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Jul 2008
    Louisville, KY
    417
    Quote Originally Posted by vette_c6 View Post
    Negative sir. Pull timing but keep AFR around 12-12.5 . Keeping it below 12 is old skool thinking. Now it's done by pulling more timing and leaning it out a bit more.
    Jun 2008
    Kuwait
    390
    If you Say so
    Abdullah Al-najdi
    00965 99369929
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    Quote Originally Posted by obonit View Post
    to answer your direct question .. you only need to u tune the high oct. table ..
    ecu uses the low oct when it detect knock ..as the knock disappears it revert to the high oct ..
    most people copy high to low when they are in the process of tuning once they fished the return the low oct back to it previous setting..
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Aug 2010
    Detroit, MI
    952
    Quote Originally Posted by SargeZ06 View Post
    I would say the old school guys just didn't understand MBT as well as we do now lol... Not to mention we have nicer dynos too
    If your spraying 200 shot id go with the 2deg per 50hp of nitrous rule.
    Pull 8 deg and shoot for a air/fuel in the 12's. Nitrous is dangerous when run rich!
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Someone wanna elaborate on boost + nitrous? Is 11.5 AFR safe considering 15 psi and 50 shot?
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by IDRIVEAG8GT View Post
    all day
    Quote Originally Posted by carlrx7 View Post
    all day
    Man speaks the truth!
    How about 1100 RWHP with boost and a little n20. If you look close you can see the wideband during the runs.
    http://www.youtube.com/watch?feature...&v=4j-o5rzVLrg
    G-FORCE Motorsports
    www.gforce-tx.com
    [email protected]
    Jun 2008
    Kuwait
    390
    nice vidoe guys ,,
    but i am not brave enough to make any Forced induction car with 12+ AFR
    i would keep it below 12
    as long as i tuned one of my friends car
    441 engine with 300 shot ,, and i had 780 RWHP spinning on dyno ,,
    and the car is still alive and he have run it more then 20 RUNS in the street + 5 on dyno
    i dont know ,, u guys might me much experience then me ,, but i hope someone explain his knowlge and feed us with information ,,,
    here you go the vidoe ,,
    sorry the vidoe is so bad ,, because i was tuning
    with low timing the car had 505 spinning a little
    should be 520 MAX
    300 wet shot 780 RWHP
    http://www.youtube.com/watch?v=kDy9ThvWbF4
    Abdullah Al-najdi
    00965 99369929
    Aug 2010
    Roswell, N.M.
    1,956
    nice vidoe guys ,,
    should be 520 MAX
    10.8AFR with all that nitrous?! No good.
    618/618 motor
    906/862 spray
    Jun 2008
    Kuwait
    390
    10.8 on unloaded dyno jet
    11.3 on street
    Abdullah Al-najdi
    00965 99369929
