Results 1 to 20 of 40
Thread: Considering an HP Tuner - 2010 Camaro 2SS
    Tuner in Training Nextphase2000's Avatar
    Apr 2012
    Kokomo, In
    25
    I have a list of mods below but basically this car was dyno tuned before I bought it. I have the tuner and the .LS2 files it uses. I manage a whole 12.1mpg. I know similar mods on other 5th gen Camaros garner much better mileage and still maintain power gains. It dyno'd at 445rwhp and def is a fast car but idles pretty rough (surging esp when slowing to a stop). Hardware all looks good. New plugs just to be safe since I bought it used with 19k miles on it.
    Bottom line is I know something is not up to par here and there are no dyno tuners in my area at all. I am pretty computer and mechanically literate thus considering doing my own tweaking. Is this the right tuner for this? I'll list my mods and hopefully the experienced folks here can shed some light on my next step...
    Thanks for any advice guys and girls!
    TDOD/AFM Delete kit and stage 2C camshaft.
    Cam specs are: 224/236 .620/.620 117 LSA
    CNC valve job the heads and port the intake and throttle body
    CNC Ported Stage 2 GM L92 Cylinder Heads
    Livernois Motorsports Dual Valve Spring Package (Livernois Motorsports Dual Valve Springs, Titanium Retainers, Valve Spring Locators, Locks, & Valve Seals)
    ARP Head Bolts
    MLS Head Gaskets
    Hardened Pushrods
    GMPP LS7 Lifters
    GMPP LS2 Lifter guide kit
    GMPP LS2 Valley Cover
    GMPP Valve Cover Breather Block-Off
    GMPP LS7 Camshaft Sprocket
    GMPP Timing Chain Dampner
    GMPP PCV Hose for Non-DOD applications
    GMPP Exhaust Gaskets
    GMPP Timing Cover w/ Sensor
    ARP Timing Chain Bolts*
    Kooks Long Tube Headers and high flow mid pipes
    PI 2400 Single Disc Converter
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    445 RWHP is very good number for Camaro
    if you have the car tuned and you are not a tuner ,, you can always
    POST the FILE Car ,,,
    IDLE for 5 mine
    Wide open throttle
    then people can tell u what do u need
    you can try to increase the airlfow or you can do it perfect thro the scanner
    if you arent experience with the HP tuner ,, its better to TRY to increase it 5% at time and see whats happening ,,
    do not SAVE over your original file ,, so u can go back to your original file if you have it mess
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Dec 2009
    So MD
    132
    I'm a little confused.
    What tuner do you have?
    Apr 2012
    Kokomo, In
    25
    I can not attach my tune file as it is an invalid file extension for this forum software. It is a different format than I think you guys are using. The tuner is the proprietary unit that came from the shop that dyno'd it. Livernois.
    The file is titled "abird_stg2c_CAI_Kooks_LT_91.LS2"
    Not sure if it can be converted to a usable format by HP or not. I assumed I would have to create a new file from scratch if I went with HP.
    Hope this is useful to someone. Thanks!
    5BA8
    3,571
    LS2 edit. When you get HPtuners I believe you can just read out the tune and then modify. If it's locked, you'll need to go a different route.
    email=[email protected]
    Jun 2008
    Kuwait
    390
    edd
    is there is a way to read a locked tune ?
    i even notice that ,, Gen 3 cars can be lock
    but gen4 some of them when you lock them ! they dont get lock !
    got idea ?
    Abdullah Al-najdi
    00965 99369929
    Tuner wreckwriter's Avatar
    Apr 2009
    West Virginia
    147
    LS2 Edit files are pretty much always locked. Only unlock is from original tuner, Vector or Livernois most likely.
    2008 Pontiac G8 GT, IHRA Modified, NHRA Pro ET
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    this is Livernois Motorsports fucking bullshit.
    Stupid bastards can't do anything right.
    The tune WILL be locked by the way. Tell them to take their crap out and we'll get it straightened up. They didn't even mess with fuel trims, basically they set the car to run in open loop all the time, because they couldn't ground a decent cam to save their soul.
    Lots of bad blood between them and I.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    5BA8
    3,571
    Quote Originally Posted by IDRIVEAG8GT View Post
    Tell us how you REALLY feel! Don't hold back, let it out man!
    As for being locked, I'm not sure about that. One of the shops I tune for pulled one (from a 5th gen), and sent it to me, and I can open it and view it just fine. Didn't try to flash it, so don't know if there would be an issue there or what, but my experience with locked 'edit' tunes is you can't open them. Matter of fact, I believe you can't even read them out, but it's been a while since I ran in to one, so could be wrong on that.
    5BA8
    3,571
    Quote Originally Posted by vette_c6 View Post
    edd
    got idea ?
    Not sure. I don't run in to locked tunes much any more. Most of the ones I have run in to though, you can read them, just not save and/or open them.
    Apr 2012
    Kokomo, In
    25
    So assuming it's Not locked, am I safe to moe forward with an HP purchase and begin workings my tune from there?
    Jun 2008
    Kuwait
    390
    if you car is tuned well
    and there is no problem ,, you dont need to do anything with it
    Hp tuner is good ,,
    alot of people know how to tune ,, many tuning shops
    but if you dont have any problem in your car ,, there is no reson to remove your tune and re-tune it
    Abdullah Al-najdi
    00965 99369929
    Apr 2012
    Kokomo, In
    25
    I appreciate the advice vette_c6 but as I mentioned early in this thread this car is drinking gas like mad and idles terrible. I am running about 4mpg less than anyone else I've talked to with similar or better mods. Thanks tho. I gotta do something here.
    Jun 2008
    Kuwait
    390
    then at the moment ,, try to download the file from the hp tuner ,, and see if this could happen or not ,,
    and if you are thinking about gas business ,
    i know i guy in the states ,,
    he is one of my teachers in the tuning ,,
    i can send you his phone number ,
    he can tune it to u ,, using Leaning cruise
    Abdullah Al-najdi
    00965 99369929
    Apr 2012
    Kokomo, In
    25
    I will have to give that a go if and when I buy this tuner. I'd hate to buy one and find out I have a locked ECM. Ouch. May have to just chance it but that's a lot of money to experiment with. On the flip side, if you guys with the experience can look at my data I pull with it and help me build from there it would be worth it. Lotsa variables for $650.00 Just not sure yet.
    even if its locked you could start from scratch and just flash over the tune that is in it
    97 k2500 ecsb 5.7l/4l80/4x4 0411 pcm,thorley tri-y's,true duals(no cats),msd ign.,zz4 cam, tuned with efi live
    Apr 2012
    Kokomo, In
    25
    Do I really need the pro version?
    Jun 2008
    Kuwait
    390
    if u are going to buy one ,, buy the pro :d
    i havent looked at the normal one ,,
    the other thing ,, everybody can help u with the Crouis and the WOT
    but if you have a big cam its hard to tune it online
    but trust me , it worth
    Abdullah Al-najdi
    00965 99369929
    Apr 2012
    Kokomo, In
    25
    I just got confirmation that my ECM is in fact locked and I do not have to stock tune file so I appreciate the advice on moving forward. Lotta knowledge and experience here. I'll stay tune (no pun intended) to this forum when I make my move. Thanks!
    Apr 2012
    Kokomo, In
    25
    I contacted Livernois and they sent me my stock files. Told me how to restore and unlock it. Pretty cool service there. Now to decide. I found a shop an hour away that will dyno tune for $450 OR...I buy my own tuner here. If I buy a tuner and send my data will some of you guys that are definitely the experts out there help with my setup?
