Results 1 to 5 of 5
Thread: 2011 Cadillac CTS V6
    Tuner in Training 1badtk's Avatar
    May 2010
    Willis, TX
    34
    Can we read this animal yet? Performance V6 with all the goodies.
    "Live Young, Die Hard, and be a Good Looking Corpse"
    1999 Ford Lightning, Built Motor, Manly Rods/Pistons
    Forged Crank, Howard Cams, Port Polished Heads
    Built 4R100 Trans, Ford Locker Differential
    Long Tube Headers, High Flow Cats (if any)
    150 - Two Stage Nitrous Intake Injected
    Eaton Supercharger with 2 lb upper, 10 lb lower
    20 lbs boost, 55 psi fuel pressure, all tuned to 14.7.
    WOT 11.8, NGK 4177 Plugs at .031
    100 Added Lbs in Rear of Bed
    28,303
    1badtk If this is the 3.0 v6 it should be E39, if you shoot support an infolog while connected to the vehicle in question I should be able to get read support added for it pretty quickly
    May 2010
    Willis, TX
    34
    Thanks Bill, I've been told by my perspective client that there are two V6's available in the CTS and his is the performance V6 with all the options available, means nothing to me being a Ford gut. But I;ll get it here and try a read.
    May 2010
    Willis, TX
    34
    I tried to read this thing again, it starts and run about half way thru then stops and says something about 3 tries and stops.
    Is there a new beta version that is reading 2011?
    28,303
    email support with an infolog.
