Results 1 to 20 of 31
Thread: Zr1 flat foot shifting tables?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Hey guys, I'm not sure how to go about finding these, but I would really like to know which tables are involved in the 2010-2012 Zr1's flat foot shifting feature (Fuel Cutoff for Full Throttle clutch in shifts)
    Anybody have any ideas which are involved?
    Thanks,
    -Robbie.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Set the park/neutral rev limiter to like 5000rpm. Works just the same.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Aug 2010
    Roswell, N.M.
    1,956
    So when you put the clutch in it thinks it's in Neutral? (References the Neutral table)
    618/618 motor
    906/862 spray
    Dec 2008
    on the Dyno
    1,825
    I've been using the P/N rpm limit for a 2 step/launch control on e38 ECM's for a while. I always disable etc on all of them because it usually results in a lazy feeling shift. On some like our shop car it's only using ignition cut for limiter and makes nice fireballs on flat foot shifting and is handy on ours because of nitrous. Don't have to worry about lean conditions from a rev limiter or rpm window malfunctions with ignition cut because the fuel is always gonna be there.
    I used a Lingenfelter LNC-002 for this on my Gen3 Camaro activated by the clutch switch and also worked very well!
    Located in Central Kentucky
    ShorTuning
    Mar 2008
    St. Louis, MO
    4,863
    ^^^ This guy is right.
    And +1 on the ETC control causing lazy shifting when doing it. You can actually see the throttle flutter in the scan on the shift.
    Jun 2008
    Charleston, SC
    969
    go here: http://xse.com/leres/ss/calculator.html
    pick your car/ trans, you can use it to find shift points via rpm or mph for each gear, helps when tweaking auto trans or in this case finding the rpm drop between shifts.
    but fyi, just set it 1000 rpms below the regular cutoff, and i always thought it was a fuel cut (per label of the table)
    Aug 2010
    Roswell, N.M.
    1,956
    Thanks for all the tips!
    618/618 motor
    906/862 spray
    Aug 2008
    31
    You mean only choose ignition rev limiter control?
    without ETC and fuel cut?
    Mar 2008
    St. Louis, MO
    4,863
    I use fuel cut to prevent the flame thrower effect.
    Aug 2010
    Roswell, N.M.
    1,956
    Flames are fun though!
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    I don't think exhaust valves like them very much.
    Aug 2010
    Roswell, N.M.
    1,956
    Good point, however, ours is removed so no worries there.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    You removed your exhaust valves? You got a rotary in that thing?
    Aug 2010
    Roswell, N.M.
    1,956
    Yep, and a what? We're running a custom Corsa Muffler setup from Wilson Header that simply doesn't have the valves. The original exhaust sounded terrible when the valves were closed.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    Quote Originally Posted by IDRIVEAG8GT View Post
    When I mentioned burning exhaust valves, I meant the actual valves in the cylinder head.
    Jun 2008
    Charleston, SC
    969
    omg
    Aug 2010
    Roswell, N.M.
    1,956
    Oh fuck. Fail. Man I feel really dumb right now.
    Let me explain however, the reason I thought you were talking about the butterfly valves in the exhaust is because:
    1. The exhaust valves shouldn't be affected by the flame because the fireball doesn't start until the raw fuel hits the hot exhaust of the car, not in the cylinder head itself.
    2. The lack of timing leaves raw fuel in the top of the combustion chamber which should actually cool the exhaust valve, not heat it.
    3. The valves in the mufflers are the only ones I could think which may be contacted by the flame.
    618/618 motor
    906/862 spray
    if i were to disable the clutch fuel cut off by maxing out speed and rpm and ect, does it still pull the timing in the table? I could just log it and see, but i want to see some fireballs. lol
    or if i have my p/n rev limit control set to spark only, does that make tht cfco automatically use spark only as well?
    Owner/Tuner Street Performance Syndicate
    06 GTO: D1SC , Full Suspension, 23X .6xx lift Ed Curtis Cam, Mast Heads, Gforce 9" 4.11 Gears, Holley High Rise, Stage 12 Fuel System, Boost By Gear
    01 Duramax: Blown Tranny (again) BWs467 Turbo, Head Studs, Exergy Injectors, Lift Pump, Moonshine
    2014 Taurus SHO: (Wife's Car) OR DPs, Tuned, CAI
    2006 TBSS; AWD SLP Catback, K&N CAI, Tuned
    Sep 2008
    1,668
    I've got my cutoff RPM set to 6600 in every gear including Park and Neutral in the "Fuel Cutoff RPM vs. Gear" table, and I still see the throttle close to 30% when I flat foot a shift.
    ...I do still have the ETC enabled in the "control method" section though. Should I disable it?
    Jun 2008
    Charleston, SC
    969
    yes
