Results 1 to 12 of 12
Thread: B1 and B2 Inj msec different?
    Sep 2011
    31
    Hey all -
    I noticed recently that my Inj B1 and Inj B2 msec at WOT are different. In the attached log (logknock) you can see where I get KR is in Cylinder 2 and B2 goes to 12.1 VS B1 at 12.6.
    The car is a twin SC61 setup on an LS2 vette. 317 heads, PRC .655 Valve springs, 228/222 .58x .58x 114.5 cam. 80 lbs inj with BAP. AFR was rich at 11:1
    What I don't understand is my dyno log is the opposite. The car used to goto 60+% duty cycle with a leaner mixture and now is only going to 55~.
    The car did not use to have this variance.
    Attachment 31436
    Attachment 31437
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    Did you do a cylinder balance test? I like to do that and have my injectors flowed. Then match injector to cylinder based on flow rate(s). That will help some. But at 11:1 you are probably getting rich knock. I would verify that 11:1 by double checking with someone that has a known good wideband BEFORE you do much more tuning. You dont want to lean it out, only to find out later that it wasnt that rich and end up damaging something.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Do you have cats?
    Sometimes my cars vary from .2-.4 on certain days. No problem that I can really see for that.
    I'm slightly concerned about having a split duration cam like that with boost, but my knowledge of your 317 heads flow characteristics is virtually zero.
    Sounds like someone messed with the data for the injectors, or your "scaled" tune wasn't scaled properly.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Sep 2011
    31
    I was always told turbos like reverse split cams. I could be wrong but the LT1 guys loved em.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    Reverse split isn't uncommon on turbo builds, although Pat G didn't spec that for me.
    OP, were your LTFTs zero before entering PE? I see bank to bank variance when a big LTFT gets carried over.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2011
    31
    I did a cylinder balance test and they were all at 100-102. My wideband was really close to my dyno run's AFR so I assume its right
    Aug 2010
    Roswell, N.M.
    1,956
    Hmm, I shall return to Google. Pat didn't spec a cam like that because your heads have some big ol intake valves in comparison to your exhausts, therefore he wanted to keep your flow characteristics balanced out for to make power efficiently. 317 heads have much smaller intake valves, and cathedral intake ports. The cam selection for style of heads versus application is totally different.
    Anyways good points upon LTFT's.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,863
    Even now, people spec out reverse split cams on LS7 heads. I don't know how to spec a cam, so I can't say the reasoning behind one or the other.
    5BA8
    3,604
    I've never seen a reverse split for an LS7 headed N/A motor. That would just be stupid.
    Reverse split cams for turbo motors are usually based on pressure ratio.
    email=[email protected]
    Mar 2008
    St. Louis, MO
    4,863
    I'm speaking in terms of turbo cams.
    Aug 2010
    Roswell, N.M.
    1,956
    Oh well, it has something to do with bleeding off boost.
    618/618 motor
    906/862 spray
    Sep 2011
    31
    turns out cylinder #1's spark plug wire wasn't not connected to the plug. once I put found that, both banks read the same!
