Car won't start.
2002 C5.2-bar speed density. Fresh HKE iron 408, ID1000 injectors scaled back, picking up cam signal in the back. 2-bar tune Started up for 30 seconds and didn't stay running. Was rich. Lowered the VE globally and tried to restart and it wouldn't start. I started troubleshooting and found no cam hi/lo signal. I reversed the A&C pins and it is now incrementing 1-1, 2-2 and so on. They incremented equally all the way. The crank signal keeps putting up funny numbers. 65536 keeps recurring. Then something like 14329. I cranked the engine over with no plug wires and it sparked down to the valve covers. I smell fuel on start and the plugs seemed to be wet when I pulled them. I pulled the starter and exhaust and inspected the cam sensor harness and metered it back to the PCM pin for pin and all was good. I verified good voltage to all injectors and coil plugs. I metered the coil grounds to the chassis. I metered all 4 PCM grounds to the chassis. I verified no pins are expanded. I changed cam and crank sensors for good measure. I pulled codes. Nothing. Not even MAF fail codes P0102 and P0103 and I'm not sure if that's related. I've tuned many SD cars and never knew if it had to actually start before the MAF fails. VATS is turned off. The MAF 101, 2&3 are set to 0 "mil on first error". MAF table is Zero'd out. Dynamic High RPM disable set to 8k, MAF fail set at 0.
I have discussed this with a tuner that I think is on top of his game, Ed Hutchings (Edcmat-l1). I am taking my O-scope over there to analyze signals. I tapped the signal wire on the Crank sensor and am getting a frequency. I know that a 24 tooth reluctor should pulse around 4800 pulses per minute with a starting RPM of 200, so that's what I'm expecting to see if it's right.
When scanning, I see No RPM signal. I see injector pulse width varying from 6ms to 11 or so.
Any suggestions while I'm in this car would be much appreciated. I'm at my wits end.
I'll post the tune and a scan when I get back to the computer that holds it.
