Wont let me put my 72 lb injectors in flow rate in?
Look at the lower right hand corner of the window.. it says 0-63lb/hr...
63lb/hr is the max without scaling them
How do you scale them out? Also we're using mass air and not speed density. Do you scale the stoich AF ratio?
Flow rate modifier vs volts
So do I take the flow rate down to 36 and double the voltage?
http://www.dsxtuning.com
Just say no to bull s***.
That's what people do with the LSJ platforms.
