Results 1 to 19 of 19
Thread: first drive of my TTix C6 Z06
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,863
    http://youtu.be/dwQbb54qkW4
    This has been a long road. The sound is absolutely intoxicating. There are only about 30 miles on the engine at this point, and we took it to 12psi. Haha. Rings seated in pretty quick.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2004
    Laurel, MD
    1,020
    Borat says NIIIICE!
    got any logs to look at?
    Mar 2008
    St. Louis, MO
    4,863
    Nothing interesting yet. I've just been checking everything over, and after about another two hours of run time, I'm going to change the fuel filter. I need to also diagnose why my pump is stalling out completely at WOT once in a while. When I cycle the ignition, it comes right back. I may have an issue with my pump speed controller not getting a clean tach signal, although it's taking tach signal right off the PCM with about two feet max of wire.
    Thing drives like stock. The fuel control is phenominal. Idling at 800rpm... trims cycle perfect. I have my over/underspeed timing set up really aggressive, which gives the car a very rhythmic idle (you can watch idle speed sine-wave back and forth from 750 to 850 which gives the sound/feel I want).
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    sound`s weak to me just kidding. when are you going to get that bad boy on the rollers.
    Mar 2008
    St. Louis, MO
    4,863
    Clutch needs some use to break it in before I really get crazy. I don't have much more to go through!
    Apr 2009
    Georgia
    148
    Very nice, looks like one hell of a ride!
    More info on this please! What do you mean by aggressive? Thanks
    Advanced Tuner imphat0260's Avatar
    Jan 2006
    STL
    537
    Nice Dave! When you plan on strapping it down over at Ben's? Can't wait to see the numbers.
    P&P Tuning
    Mar 2008
    St. Louis, MO
    4,863
    RPS told me specifically not to put it on a dyno until I had more miles on the clutch. Ben doesn't think my runflats will hold on the dyno either... and I'm pretty tapped out right now, so buying DRs isn't on my list. I might steal some he has sitting in the shop just long enough to dyno it and get SD out of the way!
    I need to change out the springs in the wastegates. 14psi as a MINIMUM is not where I want to be right now!
    Jan 2006
    STL
    537
    After the build you did, I can understand being tapped out! Can't wait to see what it puts down. BTW, how is the turf war?!?!?....
    P&P Tuning
    Apr 2006
    573
    congrats ds
    Jun 2008
    Charleston, SC
    969
    is the PSC not liking the Hobbs switch and shutting down the pump? thats how i plan to run mine when i get the turbos on.
    -Carl
    Mar 2008
    St. Louis, MO
    4,863
    Turf wars got intense!
    Carl, I had my minimum pump voltage set way too low. I had messed with it while the engine was idling. I ended up jumping power to the ignition terminal on the PSC and found that base voltage with no RPM signal was only 6.7 volts! I raised it up to 9.4 and it has been rock solid ever since. I've had no overheating problems, and no pump shutoff in boost. I think it was just trying to pull up voltage too hard or something and stalling the pump. Who knows.
    Jun 2010
    Eville, IN
    282
    any up dates.
    Mar 2008
    St. Louis, MO
    4,863
    Not really. I've only put about 600 miles on the setup. I'm hoping to jump on the dyno soon, but I really need to change my fuel filter, put softer springs in the wastegates, and install my boost controller.
    Mar 2011
    Mid West
    97
    Nice build.......
    Thanks,
    Mr. 2008 SS
    E-Fans*160 Stat*K@N Filter* FlowMaster Catback Duals*HP Tuned By Me USA
    Mar 2008
    St. Louis, MO
    4,863
    So last night we threw it on the mustang dyno at 11psi. On 93 octane and no meth it made 770whp and 800ft-lbs. IAT at the end of the run... 200 degrees. Hahaha. My IAT timing table had dropped advance down to 2-2.5 total degrees. We poured water over the intercooler, then hit it with nitrous to freeze the intercooler. Next run hit 170 and 10 degrees advance... Made exactly the same power and torque. It never gets that high on IAT on the street. I'm pretty happy. I will be cranking it to 15psi and trying again... Then I'll kick the meth on.
    Jun 2010
    Eville, IN
    282
    Tuner in Training 346ci's Avatar
    Aug 2008
    37
    Pretty sweet setup
    1998 Z-28: lid, full exhaust, 3600 stall, drag radials = 12.08@111mph
    Mar 2008
    St. Louis, MO
    4,863
    Broke the trans. Haha. Saw that one coming. In hindsight, going WOT in third up a hill with drag radials on at 16psi was killer. The T-56 was perfectly fine for the dozen pulls before that.
    Built TR6060 with a Driveshaft Shop prop shaft and poly couplers on the way. FML.
