Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Configuration & Histogram Repository
    28,314
    Aight guys as many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
    Year
    Make
    Model
    OS
    Vin
    What the config is for? Idle tuning, SD tuning, MAF tuning, General
    If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
    If you have custom histograms you'd like to post as well feel free. Same info is needed.
    Here's an example
    2001
    Chevy
    Camaro
    12202088
    2G1FP22G412102986
    MAF Tuning/VE Tuning
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    The .cfg (configuration files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2 Directory
    The .hst (histogram files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
    28,314
    Here are 4 for 98 LS1 fbodies...pretty self explanatory
    MAF tuning
    IDLE tuning
    Speed density
    An initial test config so I can compare later.
    28,314
    for 99+ LS1 fbodies again pretty self explantory
    MAF tuning
    IDLE tuning
    Speed Density tuning
    and a test for before/after results later.
    28,314
    Advanced Tuner TheDastardlyDuo's Avatar
    Apr 2005
    IL
    244
    Here's what I've been using for LS1/LS6, and LS2 configs regaurdless of year. And one I made for misfires. I've been seeing a lot of cars lately with dead cylinders.
    Have a few thousand files I can share. I'm not on here often so please email me. [email protected]
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's a "Generic Gen III" config I have been using on most all Gen III V8's with the LTFT's turned off.
    To use this one you MUST turn off your LTFT's and reset fuel trims with the scanner bi-directional controls.
    Attachment 3788
    Also you CAN/SHOULD turn off LTIT (Long Term Idle Air Trims).
    Attachment 3789
    .cfg (Config) files go in:
    C:\Program Files\HP Tuners\VCM Suite 2
    Where C:\ is the "usual" location for HP Tuners. Yours may be D:\
    .hst (histgram) files go in:
    C:\Program Files\HP Tuners\VCM Suite 2\Histograms
    Always Support Our Troops!
    Jul 2004
    1,579
    2001
    Chevy
    Camaro
    12202088
    2G1FP22G11210xxxx
    Calculating Horsepower from Delivered Engine Torque
    Converter Efficiency based off of Engine RPM and Trans Input RPM
    (Works with Manual Trans equipped)
    Delivered Engine TQ --> Calculated Engine HP = Results
    Apr 2003
    Almost 2000 feet.
    7,876
    Exclamation Configuration & Histogram Repository
    Post em up:
    Vehicle Application:
    Custom PIDs (if applicable)
    Histograms
    Here's my trans tuning stuff:
    Vehicle Application: LS1/LS6/Gen III Trucks
    Apr 2003
    Almost 2000 feet.
    7,876
    Custom PIDS & more Histograms
    Custom PIDs: (Thanks 12secSS!)
    Name: Calculated Engine HP
    Function: ([PID.2701]*[PID.12])/5252
    Name: Converter Efficiency
    Units: %
    Function: ([PID.4110]/[PID.12])*100
    Apr 2003
    Almost 2000 feet.
    7,876
    Misfire detection
    This Misfire config should work on most all Gen III engines.
    Index is the value in the table and Level is the current level. If Level exceeds Index for x amount of time it declares a misfire.
    I set up filters in the histograms that will keep spurious values out so you can make the misfire table more correct for your application.
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's a P1514 histogram to diagnose the Reduced Engine Power issue.
    Apr 2003
    Almost 2000 feet.
    7,876
    Here's an Idle tuning config for most DBW Gen III engines.
    TPS_Air.cfg
    TPS_Air_24byte.cfg is for IAC cars or cars that only output 24 bytes of data.
    Custom PID's necessary.
    AC Pressure KPA Calc custom PID:
    Abbrv: ACPressC
    Sensor: none selected
    Units: Kpa
    [PID.7101]*93.48625-15.5388
    Differential Airflow Dynamic Airflow - Desired Airflow custom PID:
    Abbrv: DifAir
    Units: %
    [PID.2320] - [PID.2220]
    28,314
    Apr 2003
    Almost 2000 feet.
    7,876
    MAF tuning Configuration
    Here's my MAF tuning with STFT's only config for most Gen III's (99+)
    Banned
    Nov 2008
    69
    I imported the "calcHP vs RPM vs TPS.hst" and it doesn't display. I've added engine RPM, TPS and the custom PID for HP. Any help?
    Advanced Tuner ajamesbond007's Avatar
    Dec 2010
    288
    Hey Bill,
    2007
    Chevy
    Silverado Half ton 5.3L V8
    12597120
    2GCEK13Z871129120
    Looking for MAF Tuning and VE tuning for part throttle applications without wideband O2.
    Thanks!
    Andrew
    Andrew
    2006 Duramax ECSB - Banks Monster Dual Exhaust, Tie Rod Sleeves, Kennedy Twin Deluxe Lift Pumps, Edge Insight CTS with Pryo, EGR Blocker Plate, PVC Reroute, Suncoast Stage 5 trans with 1056 triple disk converter, Cognito Steering Braces, PPE Race Valve, LML driver side exhaust manifold, AFE Boost Tube, Stock Drop-in BatMoWheel, ProFab Performance 3" Downpipe, Other mods along the way, TUNED by ME... Way too much fun
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    In the LS2 directory above there's the histograms for Hi/Lo MAF, but good luck SD tuning unless you really want to put the time in with bluecat's software. It works, just is overkill for most. There's a E38_E67.cfg somewhere I found on here that's setup for 07, and it has most of the common tables already setup.
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Dec 2010
    288
    Thanks Jake!
    Andrew
    Oct 2006
    Houston, TX
    646
    Quote Originally Posted by ajamesbond007 View Post
    Thanks Jake!
    Since I'm a nice person.....
    '20 AT4
    Dec 2010
    288
    That you are!!! thanks!
    Andrew
