I need the clutch pedal position signal wire pin at the ECM for this car. I thought it should be a brown/white wire at pin 16 on C2. Anybody have alldata or pin configuration for this?
clutch position sensor signal is pin 37 light green wire on the 58 pin connector. Pin 37 on the 96 pin connector is also light green, but is the map sensor signal.
