HP Tuners Bulletin Board
Go Back   HP Tuners Bulletin Board > Tuning > GM V8 Engine Tuning - Diesel Vehicles
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools
Old 12-07-2009, 09:43 AM   #1
squirrelmaster
Junior Tuner
Injector Balance Rates Help
Could anyone give me a bit of a quick rundown of the best way to check injector balance rates? I've run through every thread I can find trying stuff, but I cannot seem to get the PID supported no matter what I do, so I must be doing something wrong.
Oh, and it's on a mostly stock 2005 Silverado 2500HD LLY/Allison.
Any help would be greatly appreciated. Thanks in advance, I'm new to diesel tuning and I haven't used my HPTuners for a gas engine in so many years that I'm beyond rusty to the point of not remembering anything.
Tom
squirrelmaster is offline
Old 12-08-2009, 05:07 PM   #2
squirrelmaster
Junior Tuner
Nevermind, I got it to work. Man it has been too long...
Tom
Old 02-26-2010, 07:30 PM   #3
u00bse1
Junior Tuner
ok, Can someone steer me in the right direction. I rarely check balance rates with this program. I see the option in the scan tool but i can't get the item to work. Says bad PID or something.
u00bse1 is offline
Old 03-05-2010, 11:48 PM   #4
roy67ss
Junior Tuner
u00bse1 - did you find out how? I too will be trying to do this.
__________________
Roy
2007 GMC 3500HD, Sinlge Rear, ECLB, LBZ, Allison, 4x4
- PCV reroute, EGR blocked
2005 Chev 2500HD CCSB, Duramax, Allison, 4x4,
- LBZ mouthpiece, PCV reroute, EGR blocked
roy67ss is offline
Old 03-06-2010, 08:09 AM   #5
Dashman
Junior Tuner
Scanning Balance Rates
Open VCM Scanner, go to the Table Display, right click and insert, go to Fuel System, injectors, choose Balance Fuel Rate Cyl 1. Do again for the other 7 cylinders. Open gauge display, right click Add gauge or meter. Do that 7 more times. Right click on each gauge or meter, select properties, select the same PIDs you entered in Table Display. Your gauge or meter should read from -7 to +7. You can put an upper and lower alert from -5 to -7 and +5 to +7 for a Duramax. Good luck!
__________________
2005 Silverado 3500
LLY Duramax
128k miles
EGR delete pipe and cap plate
4" front pipe, stock exhaust back
K&N filter, stock intake
8 new injectors
Dashman is offline
Old 03-06-2010, 10:47 AM   #6
roy67ss
Junior Tuner
Thanks Dashman, I'll give it a go.
__________________
Roy
roy67ss is offline
Old 03-17-2010, 10:59 PM   #7
roy67ss
Junior Tuner
I did this today and it seems to me that the injectors are all over the place. Here is what I got and keep in mind that these numbers are kind of the running average. Some fluctuated quite a bit and others remained fairly steady.
#1 -4.5 and -1.0
#2 -3.2 and -2.5
#3 +2.5 and +1.5
#4 +0.1 and +0.2
#5 +1.5 and -0.2
#6 +3.1 and +3.3
#7 - 2.2 and -2.0
#8 +2.2 and +1.0
I think I read somewhere that -1 to +1 was ideal but anywhere from -4 to +4 was acceptable. The second readings were after I revved it up for a minute or so and seemed to be steadier than the initial ones. #1 has me kind of worried.
What do you guys think of these numbers? I do have a intermittent surge/miss at idle at a stop light and thought this might give a clue. My schrader valve is also wet which apparently might also lead to the surging.
__________________
Roy
roy67ss is offline
Old 07-28-2010, 02:41 PM   #8
bigmike06
Junior Tuner
Quote:
I tried to do this today and when i go to fuel system there is no injector menu to choose from. I even uninstalled and reinstalled still nothing. I also told it to forget last vehicle connected still nothing. Anyone know why I could not see this info? I have version 2.22. Is there a new one, this version is from 2008 and is the newest one to download from customer center. I'm I missing something?
Thanks in advance
bigmike06 is offline
Old 07-29-2010, 09:28 AM   #9
Dashman
Junior Tuner
I don't know, but it stores the PIDs for the last vehicle scanned. Maybe you need to be plugged in and at least "connect" to the vehicle. I have only ever scanned my one vehicle, so I'm not sure what needs to be done when going from one to another. I did the balance rate check with version 2.22. It is the latest official release. You sure you're opening the scanner and not the editor?
__________________
2005 Silverado 3500
LLY Duramax
128k miles
8 new injectors
Dashman is offline
Old 07-31-2010, 09:53 PM   #10
roy67ss
Junior Tuner
Dashman is right, I went thru this same ordeal a while ago. I re-read entire and all was well again.
__________________
Roy
roy67ss is offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.12
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
