TUNES/LOGS ATTACHED AT BOTTOM!!
Would this indicate a possible vacuum leak? The car has a relatively small 224/232 114LSA cam in it(Zero degrees of overlap), and bucks/surges all over the place @ 1500-1800 rpms while cruising. I've done MAF and VE tuning and no matter how many changes are made, the STFT's are still pegging -20 through -25. On the MAF values, everything is going north to +10 through +18.
Should I start chasing a vacuum leak?
