Results 1 to 17 of 17
Thread: help e85 WOT good till 4ths gear goes lean.
    Ok so I was tuning my wot today maf tuning and my car is fine in 1st-3rd but when I hit 4th gear at 120 every time my car goes lean it will be at 11.7 then go straight to 17.1 and it doesnt show up on my maf a/f error.
    Here are the logs the tune and the config.
    pls any help would be awesome.
    Jul 2009
    Winfield/Ofallon MO
    600
    some sorta dfco problem if its not reading the maf value as an error I would guess.
    I have dfco shut off because I am maf tuning. My injectors are set up right and I just rechecked my whole tune. Could it be a bad maf sensor?
    Could you be out of fuel. I know the 2.8 is pushing the limits of 80lb injectors without a return style. Dont know though.
    E-85 279.5whp/258tq
    Advanced Tuner imphat0260's Avatar
    Jan 2006
    STL
    537
    Change your STOICH to the proper E85 settings and tune your MAF right.....
    P&P Tuning
    Quote Originally Posted by imphat0260 View Post
    no thanks did that the other day didnt like the results. I had better results doing it this way. I am maxing out my injectors even though its only showing 80% my pw on them is out the roof. i have to get a return style fuel system now.
    Jul 2009
    Winfield/Ofallon MO
    600
    you should trust him, he is quite an experienced tuner. if you go your own route it seems you'll be having the issue your having.
    Quote Originally Posted by Jaxon View Post
    Nope the issue has been resolved and fixed. Ether way my way or his way its the same thing in the end. The only difference is you are raping your map when you switch to 9.7 Stoich. I know hes a good tuner but I know better tuners that know more about running e85.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Quote Originally Posted by roderick View Post
    This is not true at all, and the whole reason the stoich value can be changed in the tune is to allow for fuel changes without needing to scale everything else. There was a huge thread about this recently.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jan 2006
    STL
    537
    Actually, YOU are the one raping your tables.... To each their own... You can't tell some people something, but you can tell them nothing....
    P&P Tuning
    To both of you up top. I am not going to argue but when I tuned for stoich at 9.7 I had to add 30% more fuel through my maf and I also had to add 30% more fuel through rest of the tune because the car just didnt like the stoich set at 9.7. Ether way you do the tune it turns out the exact same whether the stoich is 14.7 or 9.7. You get a little more hp from 9.7 but its not worth the hassle.
    Mar 2008
    St. Louis, MO
    4,862
    Totally wrong, but I'm not even going to bother getting into it.
    Just like the last thread man once again have you ever tuned for E85? if not get the F$%$ out of my thread.
    Mar 2008
    St. Louis, MO
    4,862
    I've done plenty, but you clearly aren't worth wasting time on.
    Good then get out haha
    Jan 2006
    STL
    537
    Agreed...
    P&P Tuning
