Howdy,
I have a '64 Riviera with an PCM out of a 2000 Luimina hooked up to a 98 Regal harness driving an old school 4.1L Buick V6. I've hooked up all the sensors (minus the 2nd knock, the trans controls, and the emissions stuff) and wired in the PCM, the BCM, and the under hood and interior fuse boxes. Since this is a '64 Riviera, how do I get a 98-99 GTP base file to start with onto the PCM and can I program a lot of it without touching the PCM to start with. Things like diabling the emissions, 2nd O2, 2nd knock, and trans stuff as well as changing to a timing table off of an older FWD 3.8L V6 with the same heads, LQ4 MAF, disabling the VATS.
Thanks,
