i am logging actual line pressure. i have adjusted all 3 of those pressure settings and the table below those settings. gone from stock up to 200/400/300 and 200's in the upper parts of that table. i didn't see any effect on the actual line pressure.
another question. i have made adjustments to the adder/modifer part of tm. it is having an effect and i am starting to figure it out but the axis dont seem to match up with the real world. should they? anything above 258ft/lbs and anything above 5250rpm i have set at 0 and all of the torque factors are still at one. with that setting i was hopeing for some to little tm down low and full tm at wot. i ended up with full timing at wot, my tranny does not like that at all, just lets go mid shift.
i have a lot to learn and a long ways to go with this tranny.
