Originally Posted by
DSteck
Skatin, you should probably just bow out completely.
For what it's worth, I've done emissions studies and calibrations on alternative fuels for University of Michigan - Detroit, so I'm quite familiar with biofuel and ethanol.
You keep talking about gasoline and E85 having a "lambda ratio" of 1:1... This termonology is totally, well, dumb. ANY fuel has a STOICH VALUE of 1 lambda. 1 lambda for Gasoline is ~14.7, while 1 lambda for E85 is ~9.7. Rescaling the MAF is a fruit way to do it, because then any and all torque calculations in addition to cylinder load calculations are all off of what they should be, consequently compounding the problem of having to adjust MORE areas to make it "right". Just scaling the MAF up 30% when running E85 is not the right way to do anything. There is an entry for the stoich value of the fuel being used for a reason.
I can tune a car on pump gas, then fill it with E85, change the stoich ratio, and richen up the PE ratio for WOT... and it'll run without changing anything else. There's no point in building in error to your calibration when you can just do it the right way, which is actually the EASIER way.
