It's mid 80's here today and the humidity is around 25%.
First pull was 475.2 rwhp and 460.7 rwtq. The AFR was going pretty rich the higher in the RPMs that I went. I saw a couple of 10.9s. Timing was pretty low too because the intake air temps were around 130 degrees. No spark knock through the whole pull though. I made some changes to the MAF table and loaded the new tune.
Second pull was 491.4 rwhp and 484.28 rwtq. The AFR was much better this time. It was a pretty consistent 11.4-11.6. The timing was still low. Still no spark knock. I upped the main spark tables 1 degree in the WOT range and loaded the new tune.
Third pull was 494.6 rwhp and 488.52 rwtq. The 1 degree helped a little but the Intake Air Temp timing table was pulling a bunch of timing because of heat soak. I was seeing 11 and 12 degrees. Still no spark knock. I went into that table and reduced the amount of timing pulled by 1 degree and loaded the new tune.
Forth pull was 511.0 rwhp and 505.1 rwtq. For this pull I let the car cool down for about 20 minutes since the first three pulls were pretty much back to back. All in all I was happy with the last numbers. I left the tune alone since, I think it's a relatively safe tune and it didn't show any knock.
I'm happy with these numbers because I'm running a 3.7" pulley and I'm only at 6.5lbs of boost. I'll probably go down to a 3.5" pulley and "should" put me close to 8lbs of boost. I'll make that change and leave it there.
I feel good about this because I was able to make changes to my tune and see positive results.
