In the Primary VE vs RPM vs MAP table, what are the actual unit values in the table? What would I have to scan on my car to see the actual values? The description says its the airmass per cylinder but is it lbs or grams or what?
theoretical VE %
What units is VE in?
Can't remember off the top of my head.
You mind lookin it up for me?
in raw, its g/sec I am not sure if HPT converts.
thanks darkhorizon. HPT has a built in converter to convert from lb/min to g/sec.
1 lb/min = 7.56 g/sec
